Aerostar Ford Aerostar
rear heater control valve
Old Dec 7, 2007 | 11:03 AM
tk1251k's Avatar
tk1251k
My rear heat is not working.I can feel both heater hoses underneat just before they attach to rear core and where the valve is located. The hose with heater control valve is cold both sides of valve other hose hot. I assume core stopped up. But I was thinking shouldnt the heater control valve hose be hot or not? Not sure which way water passes through. thanks terry
Old Dec 7, 2007 | 11:10 AM
Bear River's Avatar
Bear River
Former ******
That valve can go bad. I believe it is vacuum controlled, so make sure the vacuum line leading to it is in good condition and is connected. A vacuum leak elsewhere in the system could also interfere with normal operation.
Old Dec 7, 2007 | 11:37 AM
tk1251k's Avatar
tk1251k
Should the line heater valve is on be hot. In other words does water flow through heater valve into core?
jasonodsky
Sep 8, 2020 05:19 PM
ExBeast
Jul 13, 2016 04:24 PM
conoso
Jun 18, 2016 07:32 AM
Daddyo's garage
Jul 1, 2014 08:23 PM
Frank Kistner Sr.
Aerostar
13
Feb 3, 2005 03:32 PM
