Sponsored by: Real Truck
10.5 rear end "click"
Old Dec 7, 2007 | 09:16 AM
rugermack's Avatar
rugermack
First off, I've already checked the brakes, thier fine. When I make a circle in a parking lot(left), I hear a "click" noise on every revolution of the rear tire. This is a rear bearing telling me its on its way out, correct ?
Old Dec 7, 2007 | 10:45 AM
rugermack's Avatar
rugermack
Does anyone know what the bearings & seals should cost ?
Old Dec 7, 2007 | 12:35 PM
tstraigis's Avatar
tstraigis
Check your u joints. Also listen for a squeaking while backing up.
Old Dec 7, 2007 | 12:37 PM
2000silverbullet's Avatar
2000silverbullet
Just throwin' this out there, but possibly the limited slip unit??? if applicable...
Old Dec 7, 2007 | 12:42 PM
rugermack's Avatar
rugermack
The u-joints make about 4 revolution per one tire revolution, I think, I would hear 4 times as many clicks.
Old Dec 7, 2007 | 12:45 PM
rugermack's Avatar
rugermack
I just changed the gear oil in that about 2 months ago, oil was clean and no shavings. The limited slip seems to be working fine right now, I realize that it could still be making noise and the revolutions would be th same as the tire. I guess with 144k on rear diff it wouldn't hurt to do (axle) bearings anyway.
Old Dec 7, 2007 | 12:51 PM
2000silverbullet
Have you noticed the noise just recently or since you changed it? Did you add in any friction modifier?
Old Dec 7, 2007 | 12:52 PM
rugermack's Avatar
rugermack
The noise is recent, I used Royal Purple and it already has the friction modifier in it.
03_PSD's Avatar
03_PSD
prolly a dumb question but have you put in any of the modifier when you changed the diff. fluid.
Old Dec 7, 2007 | 12:53 PM
03_PSD's Avatar
03_PSD
ooopsss....your too fast!!!
Old Dec 7, 2007 | 12:54 PM
rugermack's Avatar
rugermack
I think we posted at the same time, but RP already has friction modifier in it.
Old Dec 7, 2007 | 12:58 PM
rugermack's Avatar
rugermack
I'm going to work on it this weekend, I'll post results. I'm leaving work now.
03_PSD's Avatar
03_PSD
i just had my rear pinion seal done and it cost 140.00, really don't know how much bearings cost.....wait i remember a post let me find it for you.....brb
Old Dec 7, 2007 | 01:03 PM
03_PSD's Avatar
03_PSD
here is one thread:
https://www.ford-trucks.com/forums/6...ht=rear+pinion
Old Dec 7, 2007 | 03:08 PM
rwilimo's Avatar
rwilimo
Have you checked the E brakes, sometimes the shoes come apart and can make noises like that.
