Bronco II Ford Bronco II
Nothing but 4th gear
Old Dec 6, 2007 | 09:15 PM
six4pin81's Avatar
six4pin81
I've got an 87 BII, 5 speed manual. I'm driving down the freeway at about 65 in 5th when I notice the trans noise goes a bit louder and all of a sudden I notice the engine rpm jump like I'm in neutral. So I downshift to 4th and no problem, when I check the other forward gears, I have none. I should mention my gearshift has a bunch of play in it, mostly in 5th and I got the feeling my trans. needed some looking into starting about 2 weeks ago(2nd car). prior to this I had no problem with grinding gears or entering and exiting gears, in fact I can run the gears w/o the clutch very easily. What I would like to know is, new tranny or repair time. oh it's a mazda tranny
Old Dec 8, 2007 | 04:31 PM
mudslinging79's Avatar
mudslinging79
my dad had a problem with a dodge manual. what had happened is a retaining clip had come loose. i would look inside the tranny and see if a pin may have worked loose or snapped.
