Turn Signal Issue
Old Dec 6, 2007 | 07:06 AM
PSKSAM2's Avatar
PSKSAM2
Turn Signal Issue
My left turn signal is having issues. If I just casually click the stick down, the signal doesn't happen, and all I hear is a nasty sound like a relay clicking back and forth, or electricity arcing. If I pull gently towards me (without turning on the high beams) while I click it down, I can usually manage to get it to blink normally. Right turn signal works ok, as do the wipers and high beams.
I haven't gotten the time to dig into the truck or do more than a quick search of the forum, so I was wondering if anyone has seen this. Maybe I just need to change the blinker fluid...
-Jim
Old Dec 6, 2007 | 08:02 AM
pawpaw's Avatar
pawpaw
Sounds like the multifunction switch is going belly up!!!!
Ford has a service program 00B40 that covers late 90's & early 00 model vehicles, so maybe Mazda has a like program to repace the multifunction switch at no cost, so check your Dealer & see, could save some work time & bucks.
If you'll do a 00B40 forum search, you'll turn up a good bit of info on it.
Old Dec 8, 2007 | 07:30 PM
PSKSAM2's Avatar
PSKSAM2
Thanks for the pointer to the 00B40. I tried searching around but I couldn't find a similar recall for Mazda. I guess I'll look into replacing the switch myself.
-Jim
NIdude
Aug 10, 2014 06:18 AM
Troglodyte
Feb 10, 2012 09:23 AM
7.3 Ex
Mar 25, 2011 09:59 AM
islandguy26
Feb 3, 2005 07:54 PM
