Aerostar Ford Aerostar
Blower motor always running
Old Dec 6, 2007 | 03:08 AM
Qautchat's Avatar
Qautchat
Hello everybody,
I've another trouble on my 91'Aerostar :
As soon as I turn the engine key on (but do'nt start the motor), the motor of the blower AC start. Its the blower near yhe air cleaner.
I don't think it's normal.
If someonr have an idea ?
Thanks
Phil
Old Dec 6, 2007 | 04:19 AM
96_4wdr's Avatar
96_4wdr
Blower Control
The blower motor is controlled by a four-position switch located on the left side of the control assembly. The four switch positions are LOW, MEDIUM LOW, MEDIUM HIGH and HIGH. The four operating speeds are obtained with a resistor assembly connected in series with four of the switch operating positions and the ground side of the blower motor.
With the switch at LOW, current flow in the motor ground circuit is through three resistor coils to obtain the lowest operating speed.
With the switch at MEDIUM LOW (next position), current flow in the motor ground circuit is through two resistor coils to obtain a medium low motor operating speed.
With the switch at MEDIUM HIGH (position next to HI), current flow in the motor ground circuit is through one resistor coil to obtain a medium high motor operating speed.
With the switch at HIGH, current flow in the motor ground circuit bypasses the resistor to obtain the maximum blower operating speed.
The switch has no OFF position. The functional control must be at the OFF position to turn off blower.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Dec 14, 2007 | 03:12 AM
Qautchat's Avatar
Qautchat
So stupid I am.
Thaks for the informations, and I apologise for the long time before my amswer, as I am very busy for the moment.
Thanks again
Phil
Old Dec 14, 2007 | 05:25 AM
96_4wdr's Avatar
96_4wdr
vous êtes bienvenu
Necco-2
Oct 6, 2011 02:39 PM
kc5hwb
Nov 11, 2010 10:38 PM
fixit5561
Jul 27, 2010 01:59 PM
krane operator
Jun 30, 2005 10:19 PM
Willie
Jul 15, 2002 02:00 PM
