Sponsored by: Auxito
ring and pinion?
Old Mar 23, 2002 | 10:33 PM
jca787's Avatar
jca787
ring and pinion?
i have a 2000 ford e-150 with 4.2 v6..what type of ring and pinion gear do i need to buy for it...i assume it is the same as the f150 models...i want to go up to a 4.10 or so...is it an 8.8 rear or smoething else?...should i buy it from ford or aftermarket?..what about the gear for the trans to correct the speedo?..thanks
Old Mar 24, 2002 | 01:44 PM
gtex's Avatar
gtex
ring and pinion?
[updated:LAST EDITED ON 24-Mar-02 AT 02:45 PM (EST)]I see no reason to buy from Ford , unless you are under warranty. Lots of onlne places will sell you a ring and pinion. However, it should be installed by someone who knows what they are doing. So , you should probably purchase it from the shop you have install it. If it's not done right, it will be more trouble than it's worth. Find a local drive-train shop that does lots of gear changes.
As for the speedo, I think you can get one of the Chips from this site and have them adjust for the gear change.
Old Mar 24, 2002 | 07:20 PM
forddy's Avatar
forddy
ring and pinion?
