transmission
Old Dec 5, 2007 | 06:28 PM
rusty7983's Avatar
rusty7983
transmission
will the 4 spd from my 76 f350 360 fit my 77 f350 400? thanks
Old Dec 5, 2007 | 08:24 PM
STGFordCrazy04's Avatar
STGFordCrazy04
as long as you have a 351M 400 370 429 460 bell housing then....drum roll......yep!
Old Dec 7, 2007 | 07:45 AM
rusty7983's Avatar
rusty7983
thanks. i think the tranny in my parts truck is better than my driver. it needs schronizers, its real tough to get into 2nd gear.
Old Dec 7, 2007 | 07:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Replace the 4 syncronizer brass blocker rings = problem solved.
Old Dec 7, 2007 | 07:55 AM
ford390gashog's Avatar
ford390gashog
I ran into a issue swapping my NP435 for another the output shaft was bigger with a 1330 series u joint and the other was a small shaft and a 1310 series u joint. Bill is right just replace the rings.
