installing start button
Old Dec 5, 2007 | 08:45 AM
nickh's Avatar
nickh
well my key doesnt work again so im just going to put the button on the dash. i hope some1 steals it. Anyway which wires do i tie into? i am assuming these wires will be on that starter box thing on the steering colum. Please help fast i got a funeral in 2 hours and dont want to have to pop the hood.
Old Dec 5, 2007 | 06:31 PM
ford_boy_1996's Avatar
ford_boy_1996
I run a wire to the little post on the cylanoid and one to the fuse box
Old Dec 5, 2007 | 07:59 PM
flareside_thunder's Avatar
flareside_thunder
Start Button?I did it on my bronco....hell I was even stupid and didn't use an inline fuse.......one wire to the negative on the solenoid post and one on the positive.with a pushbutton.Luck
JR
Old Dec 5, 2007 | 08:09 PM
Skandocious's Avatar
Skandocious
Don't forget that you also need to give power to your fuel pump and accessories (if you want them). Good luck.
Old Dec 5, 2007 | 08:10 PM
danr1's Avatar
danr1
JR
Did ya put the button in the ligher hole? If ya did, I think I got your old bronco! lol
Old Dec 5, 2007 | 08:54 PM
icrman's Avatar
icrman
The switch powers the solenoid on the starter. So hook one wire to power (12V plus) and the other to the small terminal on the starter solenoid with the switch in between.
Old Dec 6, 2007 | 07:23 PM
flareside_thunder
Not unless it's an 89 Eddie Bauer red/tan with a 3 inch body lift straigt duals with glasspacks a 4 spd granny and it recently caught on fire........lol
JR
Old Dec 6, 2007 | 08:03 PM
danr1's Avatar
danr1
Nope, its a little blue one but it has a start button hooked up just as you described!
I plugged the wire from the ignition switch back in and it worked just fine, must be the guy that had it just liked push button start.
Old Dec 7, 2007 | 06:09 PM
flareside_thunder
He probly got drunk often and that was the easiest way......lol
JR
