1986 Second Year FI?
Old Dec 4, 2007 | 07:49 PM
zpmps2's Avatar
zpmps2
Hi all, is 1986 the second year for Fuel injection on the 300's, i knew it was for 302/351, just didnt know about the 300's, how good of gas milage will it get if it is FI in a 86 150 4x2? Thanks again guys
Taylor
Old Dec 4, 2007 | 08:25 PM
kenworthfan's Avatar
kenworthfan
1986 was the first year for all of the 302s to be EFI from the factory. In 85 they had some of the earlier ones carbed and then went to EFI. That was the only motor that was EFI in a truck in 85-86. The 351 and 300 were both still carburated then. Im not for sure when they went to EFI with the other motors.
Hope this helps
Blake
Old Dec 4, 2007 | 08:30 PM
zpmps2's Avatar
zpmps2
Hope this helps
Blake
Ok, that sucks, i thought it was EFI in 86, what mileage will i expect from this on a longbox reg cab 4 spd 4x2?
Old Dec 4, 2007 | 08:35 PM
76 F-150 390FE's Avatar
76 F-150 390FE
the first year for FI for the 300 was 87 then the next year the 351 was FI
Old Dec 4, 2007 | 08:37 PM
kenworthfan
Im not sure what the mileage would be for that. Hopefully someone else will come by and help you out there.
Sorry I couldnt help,
Blake
Old Dec 4, 2007 | 08:43 PM
zpmps2's Avatar
zpmps2
Blake
Thats fine blake, im just trying to buy a truck like i listed for 800 and just wondering if gas as high as it is would it be worth it or just buy an old altima or something!
Old Dec 4, 2007 | 08:57 PM
chrisf250-460's Avatar
chrisf250-460
well i had an 84 f150 shortbed with a 300 in it. i had 31's on it and a 3 speed automatic with no od. the truck got 13 to 15mpg but it also had 267000 miles on her.wish i still had her.hope this helps
Old Dec 4, 2007 | 09:01 PM
kenworthfan
Oh, I read your post wrong! I thought you wanted to know the MPG on the truck in your sig. I have heard of people with 80-86 F150s with 300s in them getting around 22 MPG. That would vary depending on gear ratios and if you have an overdrive or not, and your driving habits would probably affect it some too.
Hope this is helpful,
Blake
Old Dec 4, 2007 | 09:10 PM
Franklin2's Avatar
Franklin2
Be prepared for a 86 300 carbed engine to be computerized. If there is something wrong with the engine, it takes a little bit to get it sorted out. It's not as well known a system as the fuel injection is.
taylor215k
21
Nov 12, 2017 10:45 PM
donjamer
Mar 24, 2011 08:37 AM
abelmoreno
Jul 3, 2009 12:25 AM
dstruble
Mar 25, 2009 08:06 AM
