Bronco II Ford Bronco II
87 bronko 2.9 v6
Old Dec 4, 2007 | 12:28 PM
tom granger's Avatar
tom granger
87 bronko 2.9 v6
87 bronko V6 cyl 2.9Litre engine dies :
Does anyone know what the problem is?
This problem is / may be related to heat, or runtime.
It will run for four minutes, and then cuts out. regardless of load, rpm, whatever. It does not sputter or miss, no noises, no flutter,
it is like the power switch got flipped, / cut off.
After the engine cools off, the problem is gone,
and it runs again for 4 minutes.
When it runs, it is like this event never happened.
full gastank, that is not an issue.
Note gas is not bad, it runs fine normally
before and after this pesky event.
I already put in a new dist cap and rotor,
and brand new [ ignition module on the distributor].
any ideas would be appreciated. tom g
Old Dec 4, 2007 | 12:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Tom to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Dec 4, 2007 | 03:05 PM
Canadianice's Avatar
Canadianice
these symptoms are the sounds of a malfunctioning TFI Module. It is attached to the distributer and contains the ignition module. Whats happening is the module gets hot from the motor and then cuts out causing your Bronco to cut out. Just buy a new TFI Module and your problems should be cured. Just make sure when you install the New TFI module you coat the back with either thermal computer paste or dielectric grease to keep the module from conducting heat off the distributer.
Old Dec 5, 2007 | 08:18 AM
TigerDan's Avatar
TigerDan
That was my first thought as well, but he says he already replaced the module. Less likely but still possible is the pickup module inside the distributor...
Old Dec 5, 2007 | 08:27 AM
tom granger
thanks for caring and answering.
Interesting, I thought the thermal grease was to help cool the
power transistors inside the tfi module.
tom g
Old Dec 5, 2007 | 08:34 AM
TigerDan's Avatar
TigerDan
The point is that you don't want the module to get hot, heat is what kills them. Some later Ford vehicles even remote-mounted the TFI module on its own finned aluminum heat sink, a worthwhile retrofit mod for any TFI vehicle.
Old Dec 5, 2007 | 11:56 AM
5.0B2's Avatar
5.0B2
Mine ended up being an intermittent open coil winding.
Old Dec 5, 2007 | 12:10 PM
tom granger
Thanks for sharing your knowledge.
Have you heard that the HV coils are a high failure part?
respectfully and appreciatively, tom granger.
Old Dec 5, 2007 | 12:23 PM
5.0B2's Avatar
5.0B2
I only had one in 200K miles that failed. May not be your problem, but the symptoms were similar.
Old Dec 5, 2007 | 01:03 PM
tom granger
thanks again for the help
Last edited by Beast12; Dec 5, 2007 at 06:21 PM. Reason: removed "If you have a law question"
Old Dec 5, 2007 | 07:41 PM
McQue's Avatar
McQue
ok...lets troubleshoot it when it won't start...
what's missing? fuel? fuel pressure? spark? oxygen?...
McQue
