Sponsored by: Auxito
ABS/brake light
Old Dec 4, 2007 | 09:51 AM
tim nick's Avatar
tim nick
ABS/brake light
The ABS and brake light are on constantly in my 2000 F-150 2wd 5 speed manual with 155K. This happened 3 years ago and the brake guy just put in some switch, I think it was on top or the differential. Is this likely to be the problem again? Is the the switch cheap and easy to replace?
Old Dec 4, 2007 | 07:04 PM
Tagg's Avatar
Tagg
The switch for the differential is about $ 20.00 at the Ford dealership. It may be your problem , but NOT always.
Old Dec 5, 2007 | 04:43 AM
Bobby82490's Avatar
Bobby82490
Go get the codes read, then it will lead you to what you need to fix/replace.
Old Dec 5, 2007 | 06:38 PM
WALLACE84's Avatar
WALLACE84
Yes, do what Bobby said. If they did replace something on your diff. its your speed sensor. You have a 3 channel abs system
Old Dec 12, 2007 | 05:53 AM
98 F150 extcab4x4's Avatar
98 F150 extcab4x4
abs and brake light
i had the same problem, first replaced the sensor in differential, still had lights on,did the code thing, showed nothing, broke a front brake line, had all lined replaced, and while up on the rack, mechanic seen a junction block located rite under mastercylinder that been leaking, replaced that junction block, and all is good!!!! no more abs or brake light.....
1998 F150 4x4 extcab
Old Dec 12, 2007 | 09:01 PM
Norfra's Avatar
Norfra
1999 f150 4x4
Hi guys
I have a problem, the abs light comes on when I am in 4x4 and not in 2x. This happends after about a hour of driving ????
Old Dec 13, 2007 | 01:29 PM
mudvayne0882's Avatar
mudvayne0882
Problem
It is most likely the rear speed sensor, which is located on top of the rear differential. This part usually costs about 30.00 and is the most common problem. As long as it is the yellow ABS light, and not the red brake light, this is most likely going to be the problem.
Old Dec 13, 2007 | 07:41 PM
Norfra's Avatar
Norfra
Thanks and yes it is the yellow light. Will give it a try
