Driveability Issue
Truck idles fine, accelerates fine, but at cruising speed I get an sensation that the truck is being held back but only for a fraction of a second. It is intermittent and sporatic, almost like a gust of wind hitting you head on. After this happened the first time, I checked for any fault codes - none. I then disconnected the battery for awhile to clear the computer. I then took it for a drive and it seemed fine. Next time I used it, the problem appeared again. Any suggestions?
Is there a write up anywhere on how the computer works for this year truck? I would like to better understand what is being monitored and what things are managed when cruising down the highway.
Thanks for your help in advance.
Charlie Zuck
