I just finished installing new Glow Plugs and the truck is running smoother than the inside of a school marms thigh.
I did clear the codes but have not had time to drive the truck to ascertain if they returned. During the GP instalation I did disconnect the UVC harnesses and packed those connections with Silicone Dielectric grease as well as the GP plug connections at the GP's.
I just don't know what a GP Monitor Fault Bank is.
S1 DTC P1391, P1395 — RIGHT BANK AND P1393, P1396 — LEFT BANK
Note: For running KOER glow plug monitoring self test, refer to Section 2C .
One of the above codes will set when glow plugs are commanded on for over 35 seconds and battery voltage is between 11.8v and 14v, with at least one glow plug not being powered.
Key off.
Measure voltage between large wire terminal Circuit 38 (BK/O) on glow plug relay and battery ground.
