Sponsored by: Real Truck
Avg Front End Alignment Cost?
Old Dec 3, 2007 | 06:47 PM
UGA33's Avatar
UGA33
What is the average running rate of a front end alignment for an 06 F250 FX4?
Old Dec 3, 2007 | 08:55 PM
LiftedFx4F250's Avatar
LiftedFx4F250
my 03 cost me $60 after i installed my lift
Old Dec 3, 2007 | 09:01 PM
DCSpecial's Avatar
DCSpecial
$69 is what I paid for my 07 a few weeks ago.
Drives and handles much better.
My 01 was more.....but that's because of all the custom stuff on it and the guy spent half the day dialing it in perrfect
Old Dec 4, 2007 | 07:01 AM
johnjohn2784's Avatar
johnjohn2784
yea i just payed about $69 the other day on my 06 250, but if you add a lift kit they usually charge a bit more.
Old Dec 4, 2007 | 07:05 AM
GregN's Avatar
GregN
$75 at Tires Plus, or $150 (i think) for lifetime alignments.
Old Dec 4, 2007 | 10:18 AM
thedaddycat's Avatar
thedaddycat
At Sears it is about $70 for the four wheel thrust alignment, good for six months or 6K miles. You can bring it back as much as you want during that time. I get my tires rotated, balanced and alignment checked every 2500-3000 miles so the cost per alignment is around $24 for me.
Old Dec 4, 2007 | 02:38 PM
daddgonemadd's Avatar
daddgonemadd
If they are only charging $70 then all they are doing is setting the toe-in. Camber/caster adjustments require an eccentric bushing kit for the ball joints.
Old Dec 4, 2007 | 03:08 PM
ljstoy's Avatar
ljstoy
daddgonemadd is right. you have to ask them specificly to do the caster/camber adjustments. Especially if you have a lift kit. Half the time they won't have the bushings required to do it.
Old Dec 4, 2007 | 03:15 PM
Firefighter 1406's Avatar
Firefighter 1406
To adjust all with the new bushings needed was $164.00for my 99
Old Dec 4, 2007 | 03:17 PM
Ace!'s Avatar
Ace!
Are camber/caster adjustable on these trucks?
I believe thrust angle alignments are appropriate and likely in the $50 - $75 range.
Old Dec 4, 2007 | 03:38 PM
MattyNJ's Avatar
MattyNJ
Id like to know who does the extensive alignment here in NJ, Bricktown area?? anyone know?
Old Dec 4, 2007 | 06:30 PM
UGA33's Avatar
UGA33
Thanks for all the input guys.
Old Dec 4, 2007 | 07:01 PM
ryaneverk2's Avatar
ryaneverk2
My truck is in need of an alignment, as well.... timely thread.
Not looking forward to the bill for six new tires, though! Alas, it's time for new ones.
Old Dec 4, 2007 | 09:37 PM
bandlgeorge's Avatar
bandlgeorge
my f350 was quoted at $50 when I did my level kit. Luckily for me they didn't charge me since it was true after the lift.
Old Dec 4, 2007 | 09:42 PM
a-rod's Avatar
a-rod
[QUOTE=Ace!]Are camber/caster adjustable on these trucks?
QUOTE]
Yes, but theres not alot of adjustment. I just had mine aligned and WOW, no more wondering all over the road. I think mine was 60 bucks.
