Sponsored by: Real Truck
Broken Mirror
Old Dec 3, 2007 | 06:10 PM
belandd's Avatar
belandd
Broken Mirror
Ok, I screwed up. I clipped the r/h mirror while backing out of my shop. Broke the lense and the circuit board under it.
Now I suppose I need a whole new unit.
Any one have a power heated mirror for r/h side of 2006 F250 SD?
Thanks
Old Dec 3, 2007 | 06:16 PM
tac53parsons's Avatar
tac53parsons
Try eBay, it's your best bet.
Old Dec 3, 2007 | 06:51 PM
paul100's Avatar
paul100
I can't remember the part numbers but if you search you should be able to find them. The bottom line is that you have to buy the outside section of the mirror. When I bought mine (the chrome one) it was about 95 bucks from y2kfordparts.com
Old Dec 4, 2007 | 09:39 AM
1pfieffer1's Avatar
1pfieffer1
I have to replace my drivers side mirror for the same reason. How much of the inside of the door do I have to remove to do it? and how?
Thanks
Old Dec 4, 2007 | 10:34 AM
Lonewolftx's Avatar
Lonewolftx
Wink
Just the snap off section by the mirror, on the inside. Snap it off and then unbolt it.
Old Dec 4, 2007 | 10:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
For some applications, Ford sells the mirror head (or the glass only in some applications) separately.
Mirror head = Ford basic part number: 17723.
Mirror glass = Ford basic part number: 17K707.
Old Dec 4, 2007 | 10:44 AM
1pfieffer1's Avatar
1pfieffer1
Smile
Stop it.........
is it really that easy...........?
I figured I would have to remove the door panel.
thanks
Old Dec 4, 2007 | 10:53 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
You do have to remove the door pannel because the wires are down there to conect it
Nick
Old Dec 4, 2007 | 11:01 AM
1pfieffer1's Avatar
1pfieffer1
how hard it it to take off the door panel? How do I do it?
Thanks
Old Dec 4, 2007 | 11:09 AM
RACERX7775's Avatar
RACERX7775
you DO NOT have to remove the door panel or anything on the inside if you are just replacing the outside cover or the glass.
Old Dec 4, 2007 | 11:14 AM
1pfieffer1's Avatar
1pfieffer1
Have to replace the whole #@#)*&^% thing..........
Old Dec 4, 2007 | 11:19 AM
weekendwarriorfsw32
Master of Strokes
So then yes you do have to take the door panel off its real easy to do.
Nick
Old Dec 4, 2007 | 11:24 AM
1pfieffer1's Avatar
1pfieffer1
how do I remove the door panel?
Old Dec 4, 2007 | 11:25 AM
fireman28's Avatar
fireman28
If all you broke was the lens and light board then you should be able to just replace the front cover. As stated earlier it is less that $100. I had to do this on my 250 and it took 10 minutes. You do not remove anything. If I remember correctly there are 4 clips behind the glass that you can reach with a long flat screwdriver. Just move the mirror glass around to get to it.
Old Dec 4, 2007 | 12:21 PM
Lonewolftx's Avatar
Lonewolftx
Wink
Check out the Tech folder at the top of this Forum . . . You really shouldn't have to take it off thou . . . Herre is the thread from the Tech folder to make it easier for u. The mirror has two Black w/ White tracer wires attached to it at the bottom for the heating element. They just slip off to accept the new mirror.
There is also instructions as to how to take off and attach the mirror as you can easily pull out the two Adjustment pieces from the motors, which are encased in red boots for protection. I'll see what I can come up with as I have the pdf files but they aren't posted anywhere here that I know of.
http://www.eurekaboy.com/f250/doorremove.htm
