Bumper mounted reciever hitch
Old Dec 2, 2007 | 07:58 PM
SUPERDUTY_untouchabl's Avatar
Question Bumper mounted reciever hitch
Any one no of a reciever hitch that will fit our bumpers? All the ones I've found I'm going to have to weld a plate or somthing to my bumper because of the way it curls down. I cant get a regular hitch cuz my stinkin exhaust is in the way. Heres a tip for you guys. Get the hitch first, cuz now I cant get one without dang near re-doing the whole exhaust.
Old Dec 2, 2007 | 08:16 PM
FTE Trigger's Avatar
FTE Trigger
About 3/4th the way down the page...http://www.hitchcorner.com/trailer-hitches.htm
...And if you still need that spacer to get around the "curl"... I'd just throw some clearance holes through a metal plate (if you don't feel like welding it).
I know you probably know... but your still "stuck" by the bumper's capacity. But it should let you have the freedom of using most "recvr" add-ons w/no serious issues.
Old Dec 2, 2007 | 11:47 PM
mattd17's Avatar
mattd17
what kind of exhaust do you have? if it was my truck, i would feel better about getting the frame mounted hitch, and then trying to re-work the exhaust around it. im sure that any shop could re-work the tail sections fairly cheap, especially if it could be removed and just bent a little different. now, if it is welded in place, then sure it would cose more, but better insurance. how much are you planning on towing/hauling? im not sure what the bumper is rated for, but something else to keeo in mind.
