vibration
Old Dec 2, 2007 | 05:36 PM
rusty7983's Avatar
rusty7983
vibration
anybody have real bad vibrations? i think mine is the slip yoke on the driveshaft. it has some play,my truck starts shaking at 25 mph or so (speedo off). the ujoints are ok. new tires. any ideas? 77 f350 cab and chassis 160.8 wb 4 speed
Old Dec 2, 2007 | 05:42 PM
masterbeavis's Avatar
masterbeavis
check that your u-joints are not too tight. If they are, you will get a vibration. At your slip yoke, push up and down, how much play are you getting? Also, have you had your tires balanced recently?
Old Dec 2, 2007 | 06:02 PM
rusty7983's Avatar
rusty7983
i have 16.5's. they say they can't be done. that is the least of my worries as i have a slow speed vibration, it does get worse at 50. the slip joint probably has 10 thousanths of and inch slop. i had a 79 bronco and my 83 ranger had the same issue. i had the shaft rebuilt on the bronco and a new one for the ranger and they drove great after that, smooth as my daughters bottom.
Old Dec 2, 2007 | 06:27 PM
Mr. G's Avatar
Mr. G
I also have been trying to figure out an off idle and 50mph vibration. New tires (balanced), new carrier bearing, u joints tight, slip yoke doesn't seem loose...??
Old Dec 2, 2007 | 07:52 PM
rusty7983's Avatar
rusty7983
make sure the slip yoke is pulled out a little. if i pull it out about 2 inches you can see the difference in the splines, and it can be wiggled.
