not charging
Old Dec 1, 2007 | 12:56 PM
palerider125's Avatar
palerider125
not charging
This is my first diesel. 1997 ford 7.2 Any Ideas on how to remove the alternator. I cant really see where to relieve the tenson on he surpintine belt. If the alternator is bad and is replaced, are there any other components that may need to be looked at if the batteries are still not getting a charge??
thanks
Old Dec 2, 2007 | 03:22 PM
powrstrkn''s Avatar
powrstrkn'
Not sure about the 97 but on 99 and up trucks there is a 1/2'' square drive on the spring tensioner. Try posting this question in the 94 to 97 forum
Old Dec 2, 2007 | 04:25 PM
clintbonnie's Avatar
clintbonnie
You should be in the 97 forum:
https://www.ford-trucks.com/forums/forum170/
But before you pull the alternator, get a voltage meter, with the engine running you should have around 14 volts at both batteries.. If you got 14 volts, your batteries are probably bad..and your alternator is probably good.
Welcome to the Forum..
