94 bronco ??
Old Dec 1, 2007 | 09:36 AM
82MustangGT's Avatar
82MustangGT
Cool 94 bronco ??
Ok i have a 94 bronco 5.8 auto trans 33x12.50r15 with 127,000 miles
Today the truck started to vibrate on decell put it in neutral goes away only does it when its in gear trans does not slip shifts good all fliuds good check u joint all are good i need some help on this one
Old Dec 1, 2007 | 03:28 PM
Toyman's Avatar
Toyman
Check the slides in the drive shafts for excessive play, if not there then check the pinion shaft at the rear end for play. It would be very possible that there is a bearing bad in the trans case also.
Lots to check out, maybe someone can move this to the proper area for more replies.
Toyman
Old Dec 13, 2007 | 06:22 PM
82MustangGT
Cool bad day
Well got my new drive shaft for the Bronco today put it in backed out of the drive put in drive bang blew the rear end so SANTA if your read this i would a new rear axle assembly w 3.55 gears for a 94 bronco w/ abs
hope you all find this funny because i want to put a stick of dynamite in the gas tank and blow the truck sky high
so if any one knows where i can get a rear assembly in michigan let me know
1994 Bronco
4 inch lift
33x12.50 r15 mud terraind
351
e4od trans
SeminoleSlim
25
Jul 15, 2008 10:32 PM
pdx02
Jan 23, 2008 12:51 PM
brettwingfield
Sep 16, 2007 09:14 PM
chevyhater74
1983 - 2012 Ranger & B-Series
Jun 26, 2007 01:10 PM
randy332
Mar 8, 2007 06:47 AM
