First post.. Front end rattle
Old Dec 1, 2007 | 01:59 AM
4inchlovin's Avatar
4inchlovin
ok so its a 2001 f250 4x4 lb ext cab with a 6 speed.
In the front anytime i go over a series of small bumps and just driving on really bad pavement i have a very solid sounding rattle and/or knocking in the front. I had the truck on a lift checked every bolt, shocks, and other things i could find to tug on and nothing was loose. Wheel bearings are also fine. My buddies '99 4x4 has the same excact noise and still no idea where it is comeing from. Any suggestions?
Old Dec 1, 2007 | 02:33 AM
guzzle92's Avatar
guzzle92
Sway bar drop link bushings or track bar bushings. Most likely sway bar but could be both.
As much tension as there is on these components while sitting on the ground, you will not feel much while pulling and tugging on them by hand.
I just replaced my sway bar bushings with a set of poly bushings. You will have to take the drop links into a machine shop to have them pressed out but reasembly is a fairly easy job.
Old Dec 1, 2007 | 05:46 AM
Superduty krazy's Avatar
Superduty krazy
Welcome to FTE....I think that guzzle's on to it with the bushings, When there done they can hide under your truck an drive you nutz
Old Dec 1, 2007 | 07:49 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE
You can also remove your swaybar and drive around and you will know if it is the bushings.
I changed mine a few weeks ago. I didn't feel like just changing the bushings so I bought new links at the dealer.
AustinS's Avatar
AustinS
I third sway bar and sway bar link bushings. One easy way to tell is disconnect the links and drive it. That'll let you know for sure.
Austin
Old Dec 1, 2007 | 07:59 AM
miller_feed
Auston, we post at the exact same time. lol
Old Dec 1, 2007 | 08:19 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I fourth the sway bar links. I just replaced mine two weeks ago and the difference in ride quality is like night and day. I also had a front end clunk that went away after the links were replaced. The left one was so bad I could see daylight through the bottom joint.
Old Dec 1, 2007 | 08:33 AM
jrf250's Avatar
jrf250
I have the same problem on My truck also. Are the bushings something that I can get at a local parts store or dealer item?
Old Dec 1, 2007 | 08:40 AM
miller_feed
Not the dealer. They told me they are not changeable. I was getting the whole links anyway. I started to tell them they were full of it, but I let it go.
Good luck.
Old Dec 1, 2007 | 09:06 AM
guzzle92's Avatar
guzzle92
I ordered my Energy Suspension bushings online HERE.
To replace the bushings, you will have to have a machine shop press out the old ones. It shouldn't cost more than $15-$20 to have that done.
Old Dec 1, 2007 | 02:42 PM
AustinS's Avatar
AustinS
The energy suspension part #'s are 4.5186R for red and 4.5186G for black.
Just make sure your sway bar is 32mm or 1 1/4" dia. and you're good to go.
The bushing kit cost me $36.00 locally vs. $70-$80 each for new end links.
With the front end having so much weight on it, and all the road goo with oil and chemicals, they take the rubber bushings to an early grave. Polyurethane is the only way to go on these trucks.
Good luck,
Austin
Old Dec 1, 2007 | 03:33 PM
4inchlovin's Avatar
4inchlovin
Talking Thanks
Well i will give that a try. And see what happens thanks a bunch. This is the most usefull website I have found and Ive only asked one question... I have more but I will try and space them out as much as possible.
Old Dec 1, 2007 | 10:42 PM
Cold Man's Avatar
Cold Man
Another thing you can try is to look at the spring insulators. I just had mine changed and what a diffrence!!! no more noise
Old Dec 1, 2007 | 11:29 PM
jrf250's Avatar
jrf250
Thanks for all of the info. This will be the next thing I do to my Truck.
4inchlovin....Wellcome to the site. I am sure You will like it. There is a lot of very good information here to read and do to our trucks. The people on here are a greatbunch of people.
Thanks to all on FTE
