South Carolina Chapter Join Chapter, Leader: 75over77 F100
Need A Bumper Built
Old Nov 30, 2007 | 11:20 PM
YoungMT Hick's Avatar
YoungMT Hick
Exclamation Need A Bumper Built
as most of you know i will be getting my truck in mid january. the truck does not have a front bumper due to the body lift (3") and i want something better than the original on brakets. i am looking for a pre-runner tube bumper with a winch mount and front skid plat. preety general. does not have to have storage but mounts for off road light perfered. looking to lend the truck out for a bit to build. not a highboy frame so what ever frame spacing that is. has to fit over the stock grill lip like the original bumper. please send ideas prices wants concerns, questions. need helpon the idea ya maybe need help with the build he// yess. thanks guys looking to get to know most of you
FN/MM Kuper, Kenneth USN
Old Dec 1, 2007 | 09:25 AM
FTE Trigger's Avatar
FTE Trigger
A bump to make sure you don't get lost in traffic....
I've only had help in building one bumper so far (for '96? SD)... but I don't know If I
remembered all the things we Wouldn't do on the next time around.
Altho... one thing we did keep in mind during the build was to Start the build off of the truck to begin with (to make sure the mounts are 100% correct). Then we just kept the "body lines" in check with the new bumper (we didn't want a squared-off bumper for a "rounded-off" truck)
Other than that, I'm unsure... hopefully the others will chime in soon.......
by the way...I didn't have a pic handy but this picture is Similar to what it looked like except the main body of the bumper was more "rounded-looking" http://www.hbsteel.net/ca_11.aspx
Old Dec 1, 2007 | 09:53 AM
YoungMT Hick
ya thats kinda what i want but something more prerunner style front hoop large. but i will try and find ideas if anyone thinks they would like to do it let me know the truk will be in goose creek
Old Dec 4, 2007 | 08:31 PM
YoungMT Hick
does nobody do any custom work around here? just wondering or if i need to look for local shops
Old Dec 5, 2007 | 08:02 AM
TheWiz427's Avatar
TheWiz427
I have a homebuilt tube bumper from my 48 laying around here somewhere I'm not gonna use. It's a little over 6' and 3 1/2" on the tube size, I'll try to get a pic today. It's a heavy bugger!
Old Dec 5, 2007 | 03:43 PM
YoungMT Hick
thanks for the pic
FTE Trigger
I don't exactly know what shop you are "looking" for... but up here we have a few "ordinary" metal fab shops that offer things like this. So (IMO) you may want to look that way instead of just a regular "Truck accessory shop".
Old Dec 5, 2007 | 03:50 PM
TheWiz427's Avatar
TheWiz427
I don't have all the equipment to custom up a bumper. This could be a starting point if ya wanted to build it yourself, Here's the pic:
Old Dec 5, 2007 | 04:23 PM
YoungMT Hick
ok the bumper i am looking for is a front bumper. tube style front skid plate and a place to mount a winch. similar to the websits bronco. larger skid plate larger and taller main front hoop tall as the hood on my truck or a little more. lights mounting tabs and tubes extending farther down and connecting back to the frame.
http://broncozone.com/70specs.htm
Old Dec 5, 2007 | 04:36 PM
FTE Trigger
That looks kind of like some sort of Baja bumper offspring...
Old Dec 5, 2007 | 04:38 PM
YoungMT Hick
ya some sort lol. if i can get my original drawing of my bumber on here so you can get an idea or what i realy want i will try but until then thats all i have to go off of
Old Dec 12, 2007 | 07:12 PM
STGFordCrazy04's Avatar
STGFordCrazy04
If I had a tubing bender Id jump on it. If you come up with a design with a little less bends Id still help you out.
Looks like fun.
bend...drink....tack....drink....lay a bead drink the rest and repeat!
Old Dec 12, 2007 | 08:45 PM
FTE Trigger
I guess you just have to make sure you don't tack your drink to the bend then... eh?
I'd like to start back welding- and possibly help on a weekend or so... but the only welder in the garage probably hasn't been used in 10-15 (if not more) years... Its an Astro. G'Pa supposedly welded upto 3/16"-1/4" steel with it...
If anything, maybe I could help scab the material (we have a Mat'l surplus yard up here)
Old Dec 29, 2007 | 09:38 AM
FTE Trigger
Any news on that bumper?
1970f2504x4
22
Oct 23, 2023 02:27 AM
tomatu
Apr 15, 2012 07:24 PM
65fordguy
19
Jan 23, 2010 04:39 AM
1low51
Mar 11, 2007 08:18 AM
fordsrgrt
Mar 6, 2005 11:35 PM
