build sheet
Old Nov 30, 2007 | 04:24 PM
shorthair's Avatar
shorthair
build sheet
got my build sheet back yesterday & very confused they correctly show the vin # but then in the section below they refer to a f-150 reg cab 2x4 with a 5.0 gas motor as what the decodes to. Did the send me the info on the wrong vin or what?
Old Nov 30, 2007 | 05:05 PM
PLC7.3's Avatar
PLC7.3
Have you tried here... http://www.vehicleidentificationnumber.com/
or https://www.customersaskford.com/Kat...ourceSite=Ford
Old Nov 30, 2007 | 05:28 PM
shorthair's Avatar
shorthair
Thanks PLC7.3 first link does tell me that it was sold as a diesel supercab. The second link doesn't seem to be working right now.
Old Nov 30, 2007 | 07:04 PM
bigblu78's Avatar
bigblu78
http://www.customersaskford.com
type your vin in the search bar.
Old Nov 30, 2007 | 07:37 PM
Breech's Avatar
Breech
You could try this one as well.........it worked for mine: https://www.fleet.ford.com/maintenan...ls/default.asp
Old Dec 1, 2007 | 06:30 AM
shorthair's Avatar
shorthair
BIGBLU78 thanks while it did not give as much info as I'd hoped at least it told me that I wasn't seeing things when I looked at 'er since ford's letter said she was a f-150 regular cab & even I can see she's a supercab f-250 4x4.
Old Dec 1, 2007 | 07:18 AM
bigblu78's Avatar
bigblu78
I have seen what you have happen before. I my case it was because the old rusty cab was taken off of the truck and another one was put on in its place. I have done the same with swapping bodies myself. (Gotta love the Rust Belt!!) More than likely that is what is going on with your truck.
Old Dec 1, 2007 | 07:21 AM
shorthair's Avatar
shorthair
somehow I just can't envision swapping a regular cab for a super cab & have it be all that appealing plus there's the little minor difference that ford seems to think it's a coil spring 2x4 & not a leaf sprung 4x4
Old Dec 1, 2007 | 07:51 AM
bigblu78's Avatar
bigblu78
Sorry bout that... I missed the Super Cab part. Have you compaired the VIN on the truck with the VIN on the title. Are you looking at the door jamb for the VIN or on the dash plate?
Old Dec 1, 2007 | 03:34 PM
shorthair's Avatar
shorthair
Yeah the vin's match it's just that the gal at ford put someone else's info on my build sheet so now I guess she'll just have to redo it.
Old Dec 1, 2007 | 03:51 PM
Breech's Avatar
Breech
Hmmm........looks like that I link I posted isn't working. Don't know if ya still need it but let me try again.
www.fleet.ford.com/maintenance/vin_tools/default.asp
Old Dec 1, 2007 | 04:07 PM
shorthair's Avatar
shorthair
Breech thanks thats a whole lot closer to what she should have sent, & yes it was a she since I don't know too many guy's named Crystal
Old Dec 1, 2007 | 07:21 PM
Breech's Avatar
Breech
No problem, I'm sure they can get it straight for ya.
Old Dec 11, 2007 | 06:33 AM
shorthair's Avatar
shorthair
Yep they finally did get it right the decode now matchs the vin# though I had hoped that it would give the serial # of the motor.
Old Dec 11, 2007 | 08:17 AM
PLC7.3's Avatar
PLC7.3
Shorthair now your really stretching it........It is not even on my 93 build sheet. Re the build sheet location mine was under the seat between springs and foam.... happy hunting.
