90 4x4 5sd no od@ reverse
Old Nov 29, 2007 | 11:20 PM
catmacanic's Avatar
catmacanic
Question 90 4x4 5sd no od@ reverse
Just got a 90 ranger v6 4x4 5 speed, 1sp to 4th shifts ok. reverse jumps outand 5th-od can't get in . no noises, possable shift linkage, Got any ideas?
catmacanic
Old Nov 30, 2007 | 12:38 AM
RangerPilot's Avatar
RangerPilot
It won't go into either gear? Bent shift forks...you can remove the shifter and look down in the transmission from the hole for the shifter and check.
