and see what they can come up with its probobly been done with the nv4500 but the ZF would be harder with its one piece case, just pretty rare with the fe and it may run some $$$$ you might just want to go to a much lower final drive ratio say you have 3.73 or 4.10 now go to like a 3.31 or 3.08 since you have a creeper 1st already it shouldnt make much of a difference if you tow and your gas milage should improve considerably plus you wont have to change the lenth or the drive shaftes good luck
Thanks, I think AA makes the saturn od which gives a lot more split option when towing. and with a devorced case I only have to build the intermediate drive shaft
