anyone recommend a top quality coolant heating and circulating pump that will work on the 6.0. Either deisel fired or electric. Cold mornings even with the block heater are rough. Old girl chugs away at -30 celsius. Doesn't souind healthy.
Thought an espar like one would put in a kenworth, would it work? Give me your thoughts.
I always had good luck with the block heaters and an oil pan heater.
I think keeping the sump warm at -30 is just as important as the block heater.
You can buy a good one with adhesive for under $100.
Night and day difference when you fire it up.
I even stuck a small one on my trans pan.
