MAF vs SD for dummies
Old Nov 29, 2007 | 11:45 AM
dagray3's Avatar
dagray3
Hey, what exactly is MAF and SD, and how are they different? I am new to EFI, so I thought EFI was EFI. Does anyone know of a good article/webpage that could sort of fill me in? Or, if anyone has some time, just give me a quick intro for dummies.
Thanks
Old Nov 29, 2007 | 11:49 AM
Scndsin's Avatar
Scndsin
fordfuelinjection.com is a good start.
Old Nov 29, 2007 | 11:51 AM
dagray3's Avatar
dagray3
yeah, i'll check them. To make sure, it's Mass Air Flow and Speed Density, right?
Old Nov 29, 2007 | 12:14 PM
Skandocious's Avatar
Skandocious
Yes sir, MAF = Mass Air Flow and SD = Speed Density.
The basic idea is that a MAF truck uses an MAF sensor (along with other things) in the intake to tell the computer what kind of airflow it is getting, allowing the computer to adjust the A/F ratio in realtime, while the SD system simply uses a pre-programmed table that it refers to when adjusting it's A/F ratio.
The problem with SD is that if you modify your engine in a way that the pre-programmed table is no longer accurate to your engine spec, it's going to throw things out of whack, while the MAF will find the changes and adjust for them
Long story short, MAF is better for most applications This is merely my EXTREMLY basic understanding of the subject...
Old Nov 29, 2007 | 12:51 PM
Moore558's Avatar
Moore558
Speed Density is heavily reliant upon engine vacuum in order to function normally. What burns a few people is they'll put a hotter cam in their truck that won't run well with a speed density and their normal engine vacuum of say.... 20in Hg goes to 14in Hg (just an example) and in turn the computer starts giving you the finger and trying to correct for it when it really can't.
With a MAF setup you can run a bigger variety of cams and it won't hurt anything. There are pro's and con's to each though.
Old Nov 29, 2007 | 02:44 PM
17fordguy's Avatar
17fordguy
what years were sd and what years were maf?
Old Nov 29, 2007 | 02:52 PM
tomtoc's Avatar
tomtoc
and a semi-related question: does MAF = OBD2 and SD = OBD1
Old Nov 29, 2007 | 03:00 PM
Skandocious
I'm not sure exactly what years they used each of these systems but no, MAF is not always obd2. A prime example? Me! I have MAF and I'm OBD-I. I seem to remember that California got MAF more than the rest of you guys for emissions reasons... A prime example? Mike! (msb71) He has the EXACT same truck as me but lives in another state, so he DOES NOT have MAF.
Old Nov 29, 2007 | 03:01 PM
dagray3's Avatar
dagray3
yeah, I know that 88 was the first year for EFI to be standard, but do I have SD or MAF?
Old Nov 29, 2007 | 03:33 PM
eco's Avatar
eco
SD has to be reprogrammed to match changes in volumetric efficiency, vacuum etc. where as MAF will adjust itself to those changes (within a certain limit). But, the SD will perform arguably better if programmed by the right person than a MAF that has adjusted itself. Even engine wear can throw off vacuum enough to where the SD wont run the motor....but at that point the motor is probably plenty tired anyways.
Plenty of OBD1s had MAF.
Most of the time MAF has SFI which is nice where as SD usually has batch fire which is arguably not as nice of a system.
Old Nov 29, 2007 | 03:35 PM
eco's Avatar
eco
Most likely SD unless you converted. It should be easy to tell though....just look to see if there us a mass airflow sensor near the air filter housing.
Old Nov 29, 2007 | 03:39 PM
Oscar Meier's Avatar
Oscar Meier
'96 was the first year for MAF for the 4.9 L six - not sure on the eight's
Old Nov 29, 2007 | 03:40 PM
Lead Head's Avatar
Lead Head
Does a Mass Air system still use a MAP sensor for things like boost, etc..?
Old Nov 29, 2007 | 03:57 PM
eco's Avatar
eco
It uses a barometric pressure sensor.
It is basically a MAP sensor with the vacuum line left off.
Old Nov 29, 2007 | 05:21 PM
alz's Avatar
alz
some 94s got MAF
seems most of the early MAFs were 302s
