Aerostar Ford Aerostar
Flashing Airbag Light
Old Nov 29, 2007 | 07:34 AM
LTCPipkin's Avatar
LTCPipkin
Got a gremlin with a flashlight causing problems inside the instrument panel...'93 3L Aero EXT.
Airbag light is trying to tell me what's wrong, but I don't know the language. It's flashing as follows:
flash-flash-flash -- short pause -- flash-flash -- long pause
This looks like a "32" to me. What does that mean?
Michael
'93 3L Aero EXT - 212K miles
Old Nov 29, 2007 | 10:01 AM
copper_90680's Avatar
copper_90680
Clock Spring? Do the horn and the cruise control work?
Old Nov 29, 2007 | 08:34 PM
LTCPipkin's Avatar
LTCPipkin
Yup...you are right, Copper. Thanks.
The horn and cruise control have stopped working. I suppose I will disassemble the steering column in a couple weekends to replace the clock spring. I've lost my intermittent wiper setting, so plan to also replace the wiper stalk while I am in there. Any suggestions on the best source for a clock spring and the wiper stalk?
Was there an Aero recall to replace something in the steering column? Was it for the clock spring?
Michael
'93 3L Aero EXT 2WD
Old Nov 29, 2007 | 09:05 PM
ghenryl's Avatar
ghenryl
I've got a 3-2 code also but my horn and cruise work.
Do you suppose its a matter of time?
Old Nov 29, 2007 | 09:07 PM
krankshaft's Avatar
krankshaft
It's possible that the leads for the airbag in the CS have broken while the leads for the cruise and horn have not so yes.
To check this remove the airbag connector from the CS and the CS connector from the dash harness and run a continuity test through the airbag connector on the CS to the airbag wires on the connector that went into the dash.
You probably won't measure anything signifying that the airbag connectors in the CS is shot.
Old Nov 29, 2007 | 09:22 PM
ghenryl's Avatar
ghenryl
Is a clock spring on a 94 3.0L hard to change?
Old Nov 29, 2007 | 09:49 PM
copper_90680
Since Kingpin's situation is more desperate than yours, maybe you should wait till he did his and posted some pictures? How about it, Kingpin?
mbowker64
1997 - 2003 F150
Jul 26, 2010 11:24 PM
Casey429
May 12, 2010 04:57 PM
dyhrdford
Apr 16, 2009 07:22 PM
akidagin
Dec 10, 2007 01:00 PM
vMoNeY
Aerostar
Jan 21, 2004 07:31 AM
