Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Garage Door
Old Nov 29, 2007 | 01:52 AM
rmalottwtes30's Avatar
rmalottwtes30
Garage Door
a craftsman garage door. Some how when it gets cold out (I dont know might be a cowinsidense) but it will open up without any of us hiting the button, could it be someone up the road has the same door opener? How can we fix the problem?
Old Nov 29, 2007 | 02:22 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from GC.
Old Nov 29, 2007 | 06:15 AM
77f2504by4's Avatar
77f2504by4
could be anything. could be someone has a corless phone that just happens to have the same frequency. if you open up your clicker, there should be a series of 5 or 6 switches. on the door opener there will be the same 5 or 6 switches. you can change them to anything you want, as long as the opener and the clicker are both set the same.
Old Dec 6, 2007 | 07:54 PM
Bdox's Avatar
Bdox
It is possible to change the code. If you don't have a manual, Sears will if it's not too old. Or you may find instructions on the net(?)
