floor mount hi beam
Old Nov 29, 2007 | 12:56 AM
Rabbit16v's Avatar
Rabbit16v
floor mount hi beam
If I go to turn the hi beams on occassionally the lights will all go out and I have to continuosly hit the switch until they come back on. Bad switch, connection what?
Old Nov 29, 2007 | 06:09 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
Put your truck info in your posts, year, model, engine "etc"......the more info you give......the better answers you get.
If you have a floor mount dimmer switch I'd say it could be going out. Also could be your connections are dirty and corroded. Check the wires and make sure connections are good and the switch isn't moving when you push it (solid to the floor). Spray some contact cleaner in and on it too.....might help. If all that doesn't help......replace it.
Good Luck
Bob
Old Nov 29, 2007 | 06:30 AM
jnewkirk77's Avatar
jnewkirk77
Dirt and rust are your enemy here. Mine was literally caked with MUD (it was a farm truck, go figure)! But once I cleaned it and fiddled with the ground a bit, all is well. You'll probably find the same to be true. Replacement isn't difficult if that is the route you have to take, though. Ditto with the dash switch.
Old Nov 29, 2007 | 07:31 AM
Rabbit16v's Avatar
Rabbit16v
Sorry, was late and not thinking.
90 f150 4.9l
Old Nov 29, 2007 | 07:32 AM
Rabbit16v's Avatar
Rabbit16v
90 f150 4.9l
If a new one is needed, where could I find it on line?
Old Nov 29, 2007 | 08:09 AM
92F150Flare
LMC Truck......National Parts Depot.......google their catalogs
Good Luck
Bob
