Offroad & 4x4
will np205 t-case work w/ e4od?
Old Nov 28, 2007 | 07:35 AM
kjett's Avatar
kjett
If the issue is wanting to get overdrive, either spend the money for a gear benders overdrive unit, or swap to a non computer controlled AOD. Performance Automatic has come up with some seriously stout parts for the AOD that can make it almost as strong as the C6, plus the added benifit of overdrive for the street.
I guess other than looking for a stronger t-case, what will the truck be used for? Mostly street with some trail riding? Mainly off road? Mud racing? Rock crawling? Is overdrive really needed, or is it a "just would be nice to have" thing???
Old Nov 29, 2007 | 12:30 AM
82f3504x4's Avatar
82f3504x4
all i am asking is how to use a np205 with a e4od. i need od so i am not going to keep the c6 and i am not going to use an aod. someone reputable is rebuilding and updating the trans. and i have the computer taken care of, infact i am going to use this trans because of the electronic control.
http://www.baumannengineering.com/tcs.htm
Old Nov 29, 2007 | 01:17 AM
75F350's Avatar
75F350
How about a remote mount (divorced) t-case? Plenty of length in the truck, and you are going to have to modify both shafts anyway. Looks like a new crossmember will have to be made, or at least modified, so why bother with any of it?
Might even have a problem with trans clearance and big joints with a direct mount case (married), so why not eliminate all of the problems and just throw in a remots mount? Could even re-index it to gain back some clearance since you are going to modify the crossmember anyway. Seems like a reasonable solution and a very easy way to accomplish your goal.
Old Nov 29, 2007 | 02:33 AM
dwo's Avatar
dwo
A 2-wheel-drive E4OD and a divorced NP205 is the way to go. Last summer I bolted up an NP205 to my '96 E4OD, but not without a ton of work. The only easy part is that the trans and t-case have matching output/input shafts, and the same 6 bolt mounting pattern. My trans even had the notch cut out for the NP205 shift rail. I would guess E4ODs generally have this notch. The deal breaker is that the NP205 is generally compact compared to the newer aluminum t-cases that came bolted to an E4OD, so the front output yoke WILL hit the corner of the trans. The only reason I got around this is because I had to machine a new rear end of my E4OD case which broke off earlier this year. I was able to choose new mounting hole locations and rotate the t-case upward so the yoke will miss the trans. I'd have to look over my old parts to be sure, but I don't believe it would be possible to use a "clocking" ring to rotate the t-case upward enough because the t-case shift rail will interfere with existing holes in the trans mount, and visa-versa.
Old Nov 29, 2007 | 05:12 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
you need to take a pic of the e4od that you are using....some tailshafts have the notch for the shift rail apparently so ive heard and some dont.....considering the tcase that came off it doesnt use shift rails i would say it dont have it.....soooooo, either find a tailshaft that will work or mod it yourself...
Old Nov 29, 2007 | 07:02 PM
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by quadzjr
fishy,
did your tailshaft have the clearance for the shift rail for the 205 when you ran the 208? if it did was the 208 the stock case?
yes
yes
anymore questions?
-cutts-
Old Nov 29, 2007 | 07:25 PM
quadzjr's Avatar
quadzjr
well, i wish i was as lucky as you....haha
Old Nov 29, 2007 | 09:38 PM
82f3504x4's Avatar
82f3504x4
which tcases usually come on f350s w/ e4od? is there one thats stronger or better for any reason?
Old Nov 29, 2007 | 09:39 PM
82f3504x4's Avatar
82f3504x4
Old Nov 29, 2007 | 10:05 PM
fishmanndotcom
most likely the BW1356
-cutts-
Old Nov 30, 2007 | 06:47 AM
kjett's Avatar
kjett
-cutts-
Yep. The sad part is most people don't give that t-case much credit. I know that the 205 is gear driven, so there is no "chain stretch" over time. But if you think about it, the 1356 was not only used behind the 300 6-cyl, the 302 and the 351w, but it was also used behind the 7.3L turbo diesel! As was the E4OD also used behind that same diesel, so knowing that, why not just get a 1356 that is made to bolt right up to that E4OD and call it a day, for a whole lot less weight and a lower low range?
Old Nov 30, 2007 | 06:52 AM
quadzjr's Avatar
quadzjr
agreed!!............
Old Nov 30, 2007 | 11:35 PM
  #28
82f3504x4's Avatar
82f3504x4
yes i also agree, thanks
Dan92
Feb 24, 2012 07:32 AM
TheDesertRat
Oct 22, 2009 10:55 PM
mudbogger2
Feb 15, 2005 09:28 PM
