Mountaineer stalls code 1507 IAC?
Old Nov 27, 2007 | 06:30 PM
elrodalonzo's Avatar
elrodalonzo
I've got a 2002 Mountaineer and a couple weeks ago it would start and stall right out. If you gave it some gas it would stay running. It was random, but seems to be getting worse. Now it set a code, 1507 idle air control iac under speed error. Do you think changing the iac will cure this critter? Thanks for any advice you can give.
Old Nov 27, 2007 | 11:53 PM
4.0 Beast's Avatar
4.0 Beast
Yup. Sounds like a bad IAC. They arent expensive, and it is a DIY job.
Old Nov 28, 2007 | 06:08 AM
elrodalonzo
That's what I figured from my research, along with your thoughts I'll get one today and change it. Thanks for the input, this is an awsome forum for ford help. Thanks again.
Old Nov 28, 2007 | 10:38 AM
marragtop's Avatar
marragtop
You can also try cleaning the old one.
seagull369
1997 - 2003 F150
Feb 17, 2016 11:26 PM
canman47
Nov 4, 2015 10:19 AM
pinkpantherusmincus
Aug 26, 2015 12:47 AM
bobbyk01
Jan 19, 2015 06:40 AM
