Map line and boost gauge placement
Old Nov 27, 2007 | 03:50 PM
TN_F250's Avatar
TN_F250
I'm thinking of drilling and tapping my intake for the boost gauge. I've seen a couple folks have there map and boost gauge lines on the hot side (???) of the spyder (?) just after the turbo. I've read that you see boost sooner at this point. Is there any benefit to this?
Old Nov 27, 2007 | 04:03 PM
ernesteugene's Avatar
ernesteugene
It doesn't make any difference where you tap for the boost gauge, that just indicates a reading for you to look at. The thing that counts is where you tap for the MAP sensor!
Tapping the MAP sensor on the hot side helps with off the line acceleration, because the MAP sensor see's the boost sooner, which tells the PCM to add fuel sooner, and this speeds up the process of spooling up the turbo!
Old Nov 27, 2007 | 04:55 PM
mattpowerstroker's Avatar
mattpowerstroker
hey guys where can i get the part that fools the sensor so that the check engine light dosnt come on when u push more then 25 pounds of boost
Old Nov 27, 2007 | 05:14 PM
ron's power stroke's Avatar
ron's power stroke
http://www.itpdiesel.com/store.php?c...on=show_detail
Old Nov 27, 2007 | 07:02 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Forgive my ignorance but I'm learning, don't these trucks already have a MAP sensor? If so, are you saying to move it to the hot side?
Old Nov 27, 2007 | 11:56 PM
ernesteugene
Yes, connect the hose from the existing MAP sensor to the hot (turbo) side. I think it's best to leave the boost gauge connected to the cold (intake) side so you know for sure the boost is getting to the engine, and not leaking out the CAC boots!
Old Nov 28, 2007 | 07:10 AM
TurtleRacing
PSD Addict
Do you have a pic of this, I don't want to screw it up. It's probably real simple I just need to be sure.
Old Nov 28, 2007 | 08:05 AM
yellow401's Avatar
yellow401
Gene that's a great tip! Never thought about it, but for giggles I'll give it a try. Thanks!
Old Nov 28, 2007 | 09:40 AM
TN_F250's Avatar
TN_F250
Thanks Gene. Sorry for the late get back, was in labor/delivery until 3AM with nothing to show for it .
I thought this as well. To many points of failure between the hot side and the actual intake.
Old Nov 28, 2007 | 09:44 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Yah me to I dont want to screw this up.
Nick
Old Nov 28, 2007 | 09:57 AM
TN_F250's Avatar
TN_F250
I found this at Kris's (Strokin_it7.3) webshots site. http://good-times.webshots.com/photo/2525991470091838520gXkeVp
Great pic Kris!
Old Nov 28, 2007 | 01:47 PM
ernesteugene
Sorry, I don't have a pic, because I haven't done mine that way. It only helps for acceleration, and the only thing I'm interested in is towing grades! The pic above looks like a good way to do it!
Old Nov 28, 2007 | 02:50 PM
weekendwarriorfsw32
Master of Strokes
You dont have to remove the y pipe to drill this do you.
Nick
Old Nov 28, 2007 | 03:30 PM
TurtleRacing
PSD Addict
Nick
I would assume so, you wouldn't want chips in there.
Old Nov 28, 2007 | 04:06 PM
mkalck's Avatar
mkalck
Smile
I know where you went wrong there...its the female thats supposed to have the baby...try that next time.
