Engine Block Heater Question
Old Nov 27, 2007 | 02:00 PM
jj13310's Avatar
jj13310
Does anyone know if there is a fuse specifically for the engine heater in a 99 F250 Diesel? It just quit working very suddenly! jj
Old Nov 27, 2007 | 02:08 PM
ron's power stroke's Avatar
ron's power stroke
welcome to FTE it is in your fuse panel for the house..you must have tripped a breaker..does the outlet still work??? you need to run this off of at least a 15 amp breaker if the outlet is used with a short cord..if it is a long cord use a 20 amp breaker..but make sure the cord on the truck does not have a bad spot in it first and for most..dont want to start a fire
Old Nov 27, 2007 | 02:11 PM
Mike F250's Avatar
Mike F250
I have read in other threads that the cord from the front of your truck to the heater can get pinched/severed due to the way it is routed. Try following teh cord from the plug to the heater?
Old Nov 27, 2007 | 03:18 PM
jj13310's Avatar
jj13310
Thanks! I have checked the outlet and it is working. I will check the heater cord. jj
Old Nov 27, 2007 | 04:00 PM
KelVarnson's Avatar
KelVarnson
Originally Posted by ron's power stoke
...you need to run this off of at least a 15 amp breaker if the outlet is used with a short cord..if it is a long cord use a 20 amp breaker...
A longer cord will cause the heater to use less current.
Old Nov 27, 2007 | 04:47 PM
ron's power stroke
a longer cord will make it draw more current..the heater takes 1000W no matter how far away it is..how big the cord is or what the temps are..the longer the cord the more current is needed to get it all there...
Old Nov 27, 2007 | 05:54 PM
KelVarnson's Avatar
KelVarnson
In order for that to be true, the heater would have to be something other than just pure resistance. Is it? I don't think so. I think it is pure resistance.
If it is just a resistor, then a longer cord of a given gauge will drop more voltage than a shorter cord, and thus deliver less power to the load.
