Reset vacuum valve on airbox
Originally Posted by CrpssFire
How can you tell if it needs to be reset?
Air filter restriction reset
I checked mine moments ago. The yellow indicator was almost touching the red. There appear to be two gradiant lines about 1/8" apart above the red. Mine was showing it was equal to the last line next to red. I pushed the reset and the yellow deal went all the way back up into the housing. I'll see how it runs. Mine has 7700 miles on it. The air filter should not be close to being restricted. I'll look at the filter in the daylight tomorrow. If it were in the red, would I get an indicator on the dash?
where do you people dream up these "problems"? the filter minder does nothng but she YOU the restriction in the filter. it is hooked to nothing and dosent HAVE to be resetuntil you instll a new filter. as it move out it stays at the higest vacume reading that it saw. BIG real truks have been using them eversince they started using paper air filters. look at any peterbilt/kenwoorth etc and you wil see the same filter minder. the exaxt same filter mnder. it isnt a ford product.
aka:::filter minder
OK so let me get this straight.....the filter minder (AKA:Thingy) is supose to tell me what the max vacuum seen is. Then why do they call it a filter minder. It would appear to me that this filter minder should tell me when my air filter is dirty and needs to be changed. Anyways somethings up with this thingy and we all know it; its trying to tell us something and I've yet to hear what............
What people are finding out is that even with a clean filter, and the intake clear, the filter minder is still being triggered, which means under certain conditions, the engine is trying fairly hard to pull air through the intake or filter.
#28
Dreaming up problems?
Hey dude, wake up and smell the snake oil you've accused everyone of putting in their fuel tanks . . .
I must have been dreaming, along with these other guys, to see that the air filter restrictor indicator was pretty much indicating time to replace the filter. PREMATURELY I might add with all of us having clean filters. The problem is an air restriction is causing the indicators to activate. Dreaming?
You tell me if the 6.4 isn't getting enough air into the engine when it needs it? At what point does the indicator activate? Under load? High turbo? Do we even have an air restriction issue?
If you don't know, that's ok, but don't come on here and bash folks for sharing their perceptions.
Forget about the pushing of the reset and folks perception thinking it does anything. Who cares? It doesn't matter.
The real concern being expressed here is that the truck indicator is showing a restriction when it shouldn't.
#29
#30
the filter minder does nothing but tell you nhow pluged up your air filter is. unscrew it and take a look. where do you people get these ideas? you wil find one of these little jismoes on every big truck ,,they have been made and used on the big rigs for years.
