Any Advice/Tips on project
Also need to figure out what to do about the wirig to my oil pres. sending unit. Cracked all long the length. Can I order a new wire w/ connector or do I have to just splice in new wire
Any other tips or advice on other things to check while tearing into stuff?
If you splice in a new wire, use solder splices to keep the calibration of the gauge accurate. I think that the connector is only a ring lug available at any auto store.
