A 7.3 engine in good condition with a properly operating glow plug system and good batteries will readily start at -20*F without being plugged in. I don't even consider plugging mine in unless the forecast is for lower than -10*F.
I agree completely, I just dont like the sounds they make when it is 10 below starting w/o being plugged in. I just figure there if I have an outlet might as well be nice to her.
I have a heavy duty outdoor timer set to come on at 12AM and off just after I leave at 4:30AM. I like the idea of having a warm truck first thing, not 6-10 miles down the road. Plus, I don't like going out in the cold to start it. I'm testing it out for the first time tonight.
what he said..thanks for helping us all visualize the portion of the block heater most people, like myself, havent seen. it helps us understand exactly how it functions
I can say that I have plugged mine in the first thing before going hunting. Even 30 minutes makes a big diff. If not, your heater is on it's way south. I do not care how cold it is. If after 30 minutes there is no diff, it ain't working. One hour seems to be the magic number for mine. Even in the 20s, it doesn't get any warmer until I start it so I say one hour is good. Pretty much a water heater element. They fail after a while.
Edit: Great pic Kris. A water heater element. After one hour, how much warmer can we expect the block to get in the teens? No insulation there so I think anything over 1 hour is a waste as it is frittering away. Of couse in -30 temps, probably a good idea to run all night. That is brutal.
I usually plug it in when temps start dipping below 30'F for about 3 hrs. Less than 0'F then I usually leave it on all night. I have forgotten to plug it in and temps got down to -15'F ans it still started. Didn't like it but it started.
I have been driving a diesel for 6 years now and I plug mine in anytime I think the temp will hit 40 or below. I leave mine plugged in all the time because I am a Firefighter and you never know when you will get called out. I have even left it plugged in for over 24 hours before and have had no problems with do so. I don't notice if the electricity bill is any higher or not. I don't know what kind of amp draw comes from the heater. My recommendation is plug it in anytime you will need to run the heater.....it gets warm inside quicker.
I have to get use to plugging mine in again. The last 3 winters it slept in the heated garage. Now my wife insist her taurus and "our" X get the garage. I just plug it in all night when below 20. I havent noticed much in the way of electricity bill difference.
Mud...don't know what you folks are paying per kilowatt hour. Let's say it is $0.10/Kwh. Let's say "all night" is 10 hours...that is $1.00 a day to run the block heater (the block heater is a 1000 watt draw)...$30 a month. A heavy-duty timer runs about $10 and if you set it to run the three hours before you leave the house in the morning it only costs about $9 a month to run the block heater...you pay for the timer the first month AND you keep $11 for beer!
Same here...I wouldn't ever plug it in if I didn't know I had to go somewhere in the morning and it was going to go down to -20F. When the GPR and glowplugs are working properly and 5-40W oil is used, the 7.3 starts easily to subzero temps.
