Glow plug testing help please
Old Nov 25, 2007 | 08:39 PM
nightskyisme's Avatar
nightskyisme
I searched and all I can find is older Fords or the Cali systems. Mine is a federal 2001 7.3.
Lots of smoke and hard to start below 30....new GP relay already.
Can someone please forward a pin-test diagram of the glow plugs for MY rig so I don't have to pull the valve covers for nothing.
Thanks!
Old Nov 25, 2007 | 08:48 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Here ya go:
To check the harness ohm it at the Valve cover connector on the outside.
Pin Out
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
***The injectors fire with a 115VDC signal from the IDM do not pierce to wires to test.***
Ohm between "I" and "C" to test the injectors, should be less than 5.0 Ohms
To check glow plugs Ohm between "G" and battery ground should be between 0.1 and 2.0 Ohms
Old Nov 25, 2007 | 08:51 PM
Tenn01PSD350
It has also come to my attention that one should ohm the harness from the GPR to the plug that connects at the valve covers. Just throwing that out there.
Old Nov 25, 2007 | 09:00 PM
nightskyisme
Thanks, very helpful...I'll check it in the AM.....
Old Nov 25, 2007 | 09:08 PM
Tenn01PSD350
No problem. Just know it is harder than it seems without really thin alligator style clips on the meter probes. Also, the clips on the connector will come off fairly easy when you release the keepers. Just saying, be careful not to break them cause that sucks. From there it is the nine connectors I described.
Old Nov 26, 2007 | 11:59 AM
nightskyisme
Thanks for the advice....Im an Electronic Tech. so I have all those small test probes and cool "McGuiver" like tools.....lol.
Old Nov 26, 2007 | 12:34 PM
ron's power stroke's Avatar
ron's power stroke
if you get confused check this link out..it can be found in my mod's and fixes link with some other goodies in my sig below..
https://www.ford-trucks.com/forums/4...ke-thread.html
