Modular V10 (6.8l)
06 SD V-10 spark plug change
Old Jan 17, 2008 | 02:42 PM
GT4point6's Avatar
GT4point6
Originally Posted by fdnylax
I believe it's 14 ft lbs.
Watch out for debris falling into the head when the plug is removed. I had several small pebbles that would have fallen in had I not blown them out first with the blow gun.
Cool, thanks. I plan on blowing them out, break the plug loose, apply suction and then pull the plug.
What did you use to get the plug out after you loosened it since 9/16 spark plug socket doesn't have the rubber holder? Magnet? COP boot?
Thanks again,
Kevin
Old Jan 17, 2008 | 08:46 PM
fdnylax's Avatar
fdnylax
I just got lucky, they stayed in the socket when I pulled them out.
Old Jan 27, 2008 | 06:47 PM
GT4point6's Avatar
GT4point6
I finally got around to doing my plugs and it took 2 hours. Mainly due to the advise and tool list that many have posted. At 1100 hours and 55k, these plugs were worn! The bottom ground loop part has a distictive worn arch in it now that the replacments don't as well as the positive electrode being worn a bit as Well. With feeler gauges, the old plug gaps were .065-.070. I couldn't get the feeler gauges in all the way so those are estimates when I got to a thickness that no light passed on either side of the gauge.
Not sure it's a good idea to go 100k on these.
Runs smoother and throttle response seems better.
Thanks all for the tool list, tq specs and other good to do things that made this job easier than expected!
Kevin, 05 250 SD, XLT Sport V10, 4x2, 4.10, CC, Torqueshift towing the #63 CMC Mustang
Old Jan 17, 2009 | 12:56 PM
aggiect01's Avatar
aggiect01
08 v-10 plug replacement
You guys have some great advice to save time and headaches. Is there anything special that I need to know/do when changing plugs on my 08. I currently have 88K and bought the Motorcraft plugs from Advance auto parts for $12.99. Should I still use the rubber tubing and 9/16 socket. How about the anti seize spray to break them loose and should I use teflon lube on the new plugs.
Old Jan 19, 2009 | 08:27 AM
Johnny Langton's Avatar
Johnny Langton
If your '08 is a later production unit,it should have a revised plug that does not have the little ground shield "collar" that prefers to come off of the plug and stay in the head.
JL
Old Jan 19, 2009 | 01:26 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
JL
Do you have a part number for either the original or revised plug? Ford gave me SP507 as the plug number in my '08. Supposedly this is the 1 piece plug. Haven't verified that that's what is actually in the truck, it's an early '08.
Old Jan 19, 2009 | 01:28 PM
Johnny Langton
What's the production date of the truck?
JL
Old Jan 19, 2009 | 02:23 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
According to Ford, 16 Jan 2007!
Old Jan 19, 2009 | 02:57 PM
Johnny Langton
Hmm...that early might be the old style plugs....
JL
wkbrdtx
17
Jul 14, 2013 02:00 AM
calbery
Modular V10 (6.8l)
Oct 12, 2007 10:09 PM
