hedders
Old Jun 29, 2001 | 07:45 PM
rayvin_'s Avatar
rayvin_
hedders
Which hedders are you using on your 300's and how much did it cost, either did you do it yourself price or took it to a shop price, and did you get the chrome look?
Old Jul 5, 2001 | 05:06 PM
paulg's Avatar
paulg
hedders
I got a set of Clifford Performance dual outlet headers for $200. Installed them myself and had someone else do the rest of the exhaust. Nothing special like chrome or heat coating. Damn CP headers won't seal completely though!!!!!
1994 Ford F150
300-6
Highly Modified and more to come!
Old Jul 5, 2001 | 05:25 PM
72stepside's Avatar
72stepside
hedders
Hedman Hedders !! I paid $100 for them. I installed them myself not knowing that the factory coating would burn off. LOTS OF SMOKE !!!!! They sit now with a nice coat of surface rust and look like real crapola !!!
I had to notch the frame and slide the engine over to get them to fit. If I had it to do over again, I wouldn't have made the swap.
I hope my starter never goes bad. If it does, and I have to loosed the engine again, BYE BYE HEDDERS !!!!
Chris
72 F-100 Stepside
300 cid w/ Hedman Hedders
Pacer 264P 16" wheels
Old Jul 5, 2001 | 09:23 PM
troys68's Avatar
troys68
hedders
Hello,
Well, I bought a brand new set of Hedman's awhile back and have yet to install them along with my 4 bbl intake and 450 Holley carb. I went with the Hedman headers because the people I asked seemed to like them the best. But, I just read someone here had a problem with them. Oh well, whatever it takes, my header is going on.
Old Jul 6, 2001 | 01:08 PM
Eddie's Avatar
Eddie
hedders
Clifford has a new one out, a 6-3-1 design that I'm going to order next paycheck. At the same time I'm going to order Jeg's starter heat wrap.
I have a series of modifications in mind, the last one being Jet Hot Coating.
I have a '91, and supposedly the header is designed for the '90-'96 F-150.
Uh huh. Right.
Eddie
Old Aug 13, 2001 | 01:47 PM
traildawg's Avatar
traildawg
hedders
Hey Eddie, did ya ever get that Clifford header, and if so how did it work out? I'm looking to order my own, but want the scoop before I mail the check.
Jim
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.ProjectTrailDawg.com
Old Aug 14, 2001 | 08:37 AM
jwtaylor's Avatar
jwtaylor
hedders
Paulg,
I also installed clifford dual outlet on a 95. I have a question, did you have any problems installing the smog tube into the back of the rear header, I could not get this thing to line up at all (well not without some manipulation) and the large nut that screws into the header first would not fit for nothing (some modification and there it is)?? The two screws that hold the smog crap on the back of the intake also snapped with little force applied trying to get them out. Did you have any trouble like this?
Just a thought, when I did this I noticed a small increase in driveability, yet I took the clutch fan off and added an electric fan and became real happy with the difference. Thank you for your time
Old Aug 14, 2001 | 09:41 AM
paulg's Avatar
paulg
hedders
Yeah stupid Clifford Performance headers! I couldn't get the EGR tubing to connect to the header either. I had to get some plumbing 3/4" threaded piping and then abunch of other crap to connect this to the EGR valve. I finally got it connected but man was it hell of a ordeal.
1994 Ford F150
300-6
Old Aug 14, 2001 | 01:13 PM
jwtaylor's Avatar
jwtaylor
hedders
Well at least I am not the only one. Thought I was gonna lose my mind that day. All well, good luck in the future with your truck
Forgot to ask did your headers have a bung for o2 sensors in both headers? I would think the one sensor obd-1 would be more common and they would add the second bung on demand. Who knows
Old Aug 14, 2001 | 01:16 PM
paulg's Avatar
paulg
hedders
The headers I bought only had one port for the O2 sensor. 2 ports are for the 96 model inline 6s that have mass air flow!
1994 Ford F150
300-6
Old Aug 15, 2001 | 11:31 AM
jwtaylor's Avatar
jwtaylor
hedders
I would almost bet they sent me the wrong one. I even called them back and they said to just plug one up. Bet the smog would have plugged in much easier if it was the right one. Well that is in the past. Kinda sucks though to go through all that trouble if it could have been prevented.
Old Aug 24, 2001 | 03:22 PM
bigsixguy's Avatar
bigsixguy
hedders
Has anyone tried Pacesetter headers? I live in Canada and want to order all the parts at the same time from the same vendor, and Jeg's has the header, an Offy dual plane intake and a Holley 390cfm 4-bbl all for better prices than I can get elsewhere, even in Canada with the exchange rates and duties! In Alberta, we don't smog-test older vehicles so the smog fittings aren't an issue, unless they are required to make the engine run better. I am on a budget, too.
Thx folks!
Les S.
bigsixguy
Old Aug 25, 2001 | 07:26 AM
chip58's Avatar
chip58
hedders
I installed a set of Pacesetters on my Jeep 4.0. Coated them with a high-temp coating and engine building friend get from California. Don't use high-temp paint, it's crap.
I'm happy with the headers. Good value for the $ Fit and finish are pretty good, though I took a die grinder and smoothed out the inside if the flange welds.
Old Aug 28, 2001 | 04:24 PM
Eddie's Avatar
Eddie
hedders
I've decided not to do the headers; I'm just a trifle concerned about smognazi retardedness, and I'm going into stealth mode!
I'm going to use a late '70's large chamber head without air-injection in my '91 smogtruck. The air injection will be custom-tubed into ported EFI cast-iron manifolds.
The twin factory down pipes are good, mandrel-bent pieces, and they "Y" together in a precat, to which they're welded. I'm going to knock the stuffing out of that precat, so all it will be is a "Y" that looks like a precat.
Exiting the (soon to be "former") precat is a 3" diameter pipe, which leads into yet another cat, air-injected this time.
Today, I bought an air-injected, 3-way hi-flow cat from Summit--3-in. inlet/3-in. outlet. I'm going to replace that factory second cat with this new piece, which legally does everything Ford's big ol' huge massive POS does, then run 3" pipe to the existing 3" Gibson catback.
Betcha it works, betcha the smog retards never pick up on it.
Not as sexy as headers, though.
Eddie
Old Jan 1, 2002 | 12:07 AM
MustangGT221's Avatar
MustangGT221
hedders
Eddie, just wanted to know how the cat worked out. I live in mass and was curious if i just cut out the 2nd cat and put in that summit cat if i would still pass emissions testing.
