Four Wheel Drive Overdrive?
Old Nov 25, 2007 | 06:19 PM
714x4's Avatar
714x4
Lightbulb Four Wheel Drive Overdrive?
I have a 1971 3/4 ton, four speed, four wheel drive, It is currently a farm truck but I am looking to make it more of a driver also. I like the low end torque but don't like the high RPM's at cruising speed. I am thinking about an overdrive. I also have a 1968 1/2 ton, two wheel drive, with a three speed and overdrive. I was wondering if I could swap the overdrive into the 4x4 between the transmission and the transfer case. Any thoughts would be appreciated.
Thanks, Seth
Old Nov 25, 2007 | 06:52 PM
wizzard351's Avatar
wizzard351
real the easyest way to get od would look at advance adapters they have an od unit that goes between the 4sp and the bell,all you would need to do is shorten your middle drive shaft and install the new shifter.years ago i junked a truck that had one of these i shouldve spent the time to keep it
Old Nov 26, 2007 | 06:01 PM
714x4's Avatar
714x4
Thanks for the idea. I took a look and I didn't really care for the $1500 price tag. I would like to use what I already have if it will work
