Weight
Old Nov 25, 2007 | 03:54 PM
sid318's Avatar
sid318
Weight
Hi guys not posted for a while , busy getting on with truck rebuild , does anyone know of the weight of 55 f1, rough idea, mine has volaire clip 351w c4 & 9" , well will have when done !! even better front & rear weights, cheers guys when i have time & work out how to post pics will do.
Old Nov 25, 2007 | 04:34 PM
Randy Jack's Avatar
Randy Jack
I weighed my 56 on a truck scale at work. 3500# total, 2200# on front, 1300# on rear wheels. Mine has an MII IFS and a 351C, so we should be pretty close.
BTW, you have an F100. The F1's were between '48 and '52.
Old Nov 26, 2007 | 08:55 AM
sid318's Avatar
sid318
Cheers Jack, should help me with what t/converter to get , lot of power going to go through it, u have any traction problems,i'm fitting 4 bar set up, will fit biggest w/tyre combo poss, just starting to fit r/end now.
Old Nov 26, 2007 | 09:27 AM
Randy Jack's Avatar
Randy Jack
I have mono leaf springs and traction bars on a 3.50:1 9-inch limited slip rear. https://www.ford-trucks.com/user_gal...134719&width=2
I run P295/50R15 rear tires (12" wide), but my fenders are 2" wider than stock. The biggest tire I could fit under the stock fenders was P275/50R15.
Old Nov 27, 2007 | 09:16 AM
sid318's Avatar
sid318
Thanks for info Jack, let u know how i go on with 4 bar kit , ie what wheel / tyre combo fits, plenty big enough tyre 275/ 50 /15, hoping to go to 17 inchers, so will have a look what is equal to them, any pics of your truck , especially rear end , love rear ends !u drag raced truck ? your oversized rear fenders , are they glass ? do u have traction probs ? or is there lead in the bumper !
Old Nov 27, 2007 | 10:03 AM
Randy Jack's Avatar
Randy Jack
Sid - Click on the user's name in the post header and a menu drops down. Click on "View Gallery" and voila! the person's FTE gallery shows up.
Or, if you're feeling a little lazy today, here's mine: https://www.ford-trucks.com/user_gal...?userid=201514
