Fuel Filter valve
Old Nov 25, 2007 | 03:29 PM
dzzavid's Avatar
dzzavid
Fuel Filter valve
Has any one had a problem with thier fuel filter valve? mine is closed but its not stoping fuel from leaking out it is a slow drip when it is running, any one have this problem before?
-dave
Old Nov 25, 2007 | 03:38 PM
ron's power stroke's Avatar
ron's power stroke
yes sir..very common.dealer only sells valve with oring for around 60 bucks..take these ## to a parts store and pick up just the orings..thats what goes bad in the valves....make sure they are diesel rated.
<TABLE id=DataGrid1 style="BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=3 rules=all border=1><TBODY><TR style="FONT-SIZE: smaller; FONT-FAMILY: Verdana, Arial, Helvetica, sans-serif; BACKGROUND-COLOR: #f2f2f2"><TD>Fuel Drain Valve</TD><TD>Viton</TD><TD>1/8"</TD><TD>1/4"</TD><TD>1/2"</TD><TD>Grainger</TD><TD>1BYU7</TD><TD>25/$5.16</TD><TD>202</TD><TD></TD></TR><TR style="FONT-SIZE: smaller; FONT-FAMILY: Verdana, Arial, Helvetica, sans-serif; BACKGROUND-COLOR: #e5e5e5"><TD>Fuel Drain Valve</TD><TD>Viton</TD><TD>1/8"</TD><TD>1/4"</TD><TD>1/2"</TD><TD>McMaster-Carr</TD><TD>9464K118 </TD><TD>25/$5.46</TD><TD>202</TD></TR></TBODY></TABLE>
this is how you fix it..
http://home.centurytel.net/sabre/drainvalve.html
aocabrown's Avatar
aocabrown
Do a search for fuel filter or fuel pump. You'll find a thread about the valve leaking and several people have reported that they had to replace the valve in some manner. I just ran across it while trying to determine if I have a air / fuel / performance issue.
Old Nov 25, 2007 | 03:40 PM
aocabrown's Avatar
aocabrown
Darn it Ron....you beat me to the punch. I thought I was FINALLY going to be able to help someone first.
That is the great thing about this place. Folks are ready, willing, and able to help. I'm just starting to pick up enough common knowledge to add in (a little)
Old Nov 25, 2007 | 03:49 PM
dzzavid's Avatar
dzzavid
Thank you so much guys!!!
Old Nov 25, 2007 | 07:18 PM
Orezona's Avatar
Orezona
Yep, can you imagine a better place where people actually hurry to be the first to help you out in the time of need.
Old Nov 26, 2007 | 07:42 AM
dzzavid's Avatar
dzzavid
Where did you guys buy these rings? i tried napa and autozone and they said that they did not have them.
thanks again!
Old Nov 26, 2007 | 07:57 AM
ron's power stroke
try IH dealer or hydraulics shop first..i am suprised Napa does not have them..but you can get them here as well..get the $10 set and get 2 sets..you will need them again some day.its $20 to have them overnight though..
http://www.dfuser.com/mfg/powerstroke/73/Engine/O-Rings/O-Rings.php
i see them on ebay yesterday..2 bucks for one set..
Old Nov 26, 2007 | 07:59 AM
ron's power stroke
here is the onse on ebay..there $2.50 a set
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Old Nov 26, 2007 | 08:12 AM
guzzle92's Avatar
guzzle92
After doing a little research, there are many different flavors of VITON. Viton is just the registered trandemark of Dupont's but there are many different compounds of this kind of polymer. AL, A, BL, GBL, B, ETP, GFLT, GBLT , F, GF and TBR and each one reacts to chemicals such as #2 diesel fuel, biodiesel and petroleum products differently.
THIS is where I got mine.
Old Nov 26, 2007 | 08:17 AM
dzzavid's Avatar
dzzavid
thanks again!
Old Nov 26, 2007 | 03:30 PM
yellow401's Avatar
yellow401
EXCELLENT information fellas! I need these exact o-rings.
Guzzle, nice source. I'm confused: they sell brown and black orings for the fuel drain valve, with the brown being $1 more than black? What is the difference and which do I need? IIRC, the stock orings are yellow. Thanks
Old Nov 26, 2007 | 03:43 PM
guzzle92's Avatar
guzzle92
Brown & Black?? Yes, I saw that but on many websites that I found, Viton (A) is Viton (A) and Viton (F) is Viton (F), no matter what the color.
Apparently, there is a color standards for orings and material but nobody adhears to it. I guess some people just like brown.
I also found this on another site:
"Q: Is there any difference between black and brown Viton o-rings?
Many different formulas have been used for Viton over the years, but black and brown Vitons are functionally interchangeable. Depending upon the formulation, the one may be slightly softer than the other, and black ones contain carbon black. The 'Chromassure' uniform color coding system was adopted to simplify identification of the different polymers, but it obviously isn't being followed as fluorocarbon o-rings (which include Viton, Kalrez and Kel-F) are all supposed to be black."
I don't think that the original FORD orings are Viton and the yellow is just a coating that starts to flake off (and probably assists in causing the leak to begin.)
Old Nov 26, 2007 | 03:46 PM
ron's power stroke
very nice link guzzle thanks alot..i am book marking this one...
Old Nov 26, 2007 | 03:50 PM
yellow401's Avatar
yellow401
Perfect! Thanks for the help! Would you beleive I just called the dealer on these earlier today and was told I could buy the entire valve for $50 or could buy an entire o ring seal kit for all ports on the fuel bowl for $36!! It's amazing...
Thanks again for the help. I'm ordering two sets of black Vitons!
