General Diesel Discussion
Newbie needs advice.
Old Nov 25, 2007 | 01:08 PM
powderpig's Avatar
powderpig
I live in a British Columbia ski town at the top of a steep 11 km hill. My mini excavator and trailer weigh 15000lbs. I own a Chevy 6.5L diesel, automatic, one ton dump that does not have any pull or hold back. All advise is steering me toward a F450 7.3L Turbo 4x4 manual. Everything I read about the 6.0L diesel is not favorable. I would love to hear about any experience towing with either of these engines. Taking all advice - bring it on gentlemen.
Old Nov 25, 2007 | 05:25 PM
F350-6's Avatar
F350-6
I traded my 95 6.5 auto for a 99 F350 stick and there is a world of difference in pulling 15,000# between those 2 trucks. I've since switched most of the work fleet over to Fords and have also discovered they don't break down as much. I never had any major problems with the Chevy's (except for transmissions in the late 90's), but once they got around 175,000 it seemed like little stuff broke every month.
The early 6.0's did have issues which were resolved in later years. I've got some 06 & 07 trucks in the fleet that haven't had any issues, but they don't have enough miles on them for me to comment on longevity. I've still got a few 7.3's running strong at or above the 200,000 mile mark.
Whichever you choose, hang around here so you can learn about whatever quirks the motor may have just in case something goes wrong.
Old Nov 25, 2007 | 07:57 PM
Dustin1690's Avatar
Dustin1690
Yeah it was only the years of 03 04 that the 6.0l where somewhat problematic but even so many people on here say they have a 03 04 6.0l with so and so many miles and its been trouble free
I hear good things about the 7.3 all the time so i really i think you would be happy with one im sure it would tow that no problem but test a few out
Old Nov 27, 2007 | 12:43 AM
powderpig's Avatar
powderpig
Hey Guru
Thanks for sharing. I bought the chevy being fooled by a good body and solid dump box. I am very disappointed in the motor and its towing ability. From all appearances on the road the Fords seem to be the work truck of choice in the medium GVW range. (F350-550) Although I think the Duramax are gaining some ground.
As well, this is the first automatic vehicle I have ever owned. For some totally uneducated reason I have never trusted them. I would be curious to hear of your experience - Standard vs Auto.
Old Nov 27, 2007 | 06:02 AM
F350-6's Avatar
F350-6
That Chevy was the first (and last) auto I ever bought for myself. I prefer the stick for heavy loads since you can choose what rpm's you want to run at and don't have to worry about an auto hunting gears, or trying to downshift 2 gears on you when you give it a little throttle. I also like having the ability to down shift, not to mention the fact that the truck will slow down when you lift your foot off the accelerator. If you haven't driven a Ford 6 speed you'll be surprised with the granny gear. It's only good up to about 3 MPH but you could pull a house off it's foundation without even coming close to smoking the clutch.
The new autos are supposed to be much better, but then again they told me that back in 95 and I fell for it. The newer duramax will run circles around that 6.5 also. It was just a bad motor.
Good luck on your decision.
Old Nov 27, 2007 | 11:44 AM
rollerstud98's Avatar
rollerstud98
Lots of the continuous problems with the early 6.0's were caused by techs not knowing how to work on them and just repeatedly throwing parts at them without a proper diagnosis. Also guys who do not do regular maintenance have usually more problems, you need good oil in the 6.0's always or you'll start to thrash your injectors.
Old Nov 27, 2007 | 01:51 PM
ghunt's Avatar
ghunt
Being on such a steep hill, you may also want to look into an exhaust brake.
