Need help
Old Nov 25, 2007 | 11:54 AM
Ionlydrivefordtrucks's Avatar
Need help
Hi i have a 1991 ford f150 with 300 six and a manual tranny what I need is to know how do i find out if my truck has max cooling or not im trying to get a new radiator.
thank you
Old Nov 25, 2007 | 01:23 PM
TheRoadVirus's Avatar
TheRoadVirus
Well, I would think that the max cooling would just be a thicker radiator with another row but don't quote me on that. If it's just a regular radiatior it'll be fairly thin and if it's "max cooling" it'll be thicker. Sorry I can't be more precise.. I don't know where my damn tape measurer is or I'd measure mine (non max cooling) it's about an inch in thickness (one row).
Old Nov 25, 2007 | 02:02 PM
Bdox's Avatar
Bdox
Are you having an overheating problem?
If not, the stock radiator does a really good job.
Old Nov 25, 2007 | 03:20 PM
Well You Can Say That Im Having An Overheating Problem Since My Old One Has A Hole In It On One Side Its A Slight Problem What Do You Think?
Old Nov 25, 2007 | 04:15 PM
Bdox's Avatar
Bdox
I have an 86 with the 300 six. When I first got it and saw that radiator my first thought was that it was too small and that it had to go. This was I bought the truck for the back country down in Mexico. So I knew I would be heavily loaded, going deep off road in very high heat for a long time. But as I was fixing the truck up in preparation for the first trip I saw that it kept the truck cool in summer at high altitude, loaded and going over mountains so I left the radiator in place. I have used it for a number of years, (nine I think,) in some pretty extreme conditions and it has never run hot. Not even a little bit.
So unless you are planning to tow something heavy over the Rockies, I think your stock one row radiator is fine for that 300 six.
On a side note. A one row radiator is the most efficient. More rows of tubes adds capacity but lessens efficiency. If you are paying attention to such things you will find that many new vehicle radiators are one row. The radiators are thicker than ours, that one row of tubes may be an inch or an inch and a quarter thick. Often the tubes are dimpled to promote turbulent flow too.
If you feel the need to increase your radiator capacity, it is better to increase the frontal area than the thickness if you can find a way to do it.
Old Nov 25, 2007 | 06:34 PM
well thank you for the info
Old Nov 25, 2007 | 09:01 PM
TheRoadVirus
Lol, good info but I'm pretty sure he's just trying to find a stock replacement which would probably be better either way for ease of installation.
