6.9L wiring harness 8 pins
Two big orange/white wires go to the glow plugs and back to the glow plug relay mounted on the passenger side inner fender. Use AWG 10 wire for this and run seperate wires for each to the glow plug relay.
Red/green goes to the fuel shut off solenoid, it needs power to start and run, so it would go to the coil wire + that comes from the ignition switch on a gas truck.
This wire also powers the fast idle solenoid and cold timing advance solenoid on the IP.
White/red goes to the oil pressure guage.
Red/white goes to the temp guage.
Red/black goes to the overheat light.
That is what you would find on a F series, not sure if the E series is a bit different.
