Sponsored by: Real Truck
ABS light due to speed sensor?
Old Nov 29, 2007 | 07:58 PM
Barney674's Avatar
Barney674
Glad to help!
1. I was wondering if the Code from your scanner was P0503 or P0720, or P0722? This would definetely pinpoint the problem.
2. I was wondering if your ABS light is blinking before it stays on?
3. Also, if your brakes are real low, you will get an ABS light on your dashboard, mainly from the front rotors.
4. Extra info, when the brake cylinder runs low or the switch under the reservoir gets gummy, it may flash the ABS from time to time.
Good communication can solve many issues! Good hunting.
Old Nov 29, 2007 | 08:34 PM
Jack_99V10's Avatar
Jack_99V10
Barney...
I just got done hacking off my muffler, and while I was under there I wiggled the sensor on the diff. Not a lot... because my trouble light died, and it was really dark under the truck, but a little. When I got in for my testdrive I almost made it out of my driveway with the light off. Once I got about 3/4 of the way (about 100 ft) down the drive it came on and stayed on. Wiggling it helped lol
I'll take it off once I get back into the garage and clean it out. I don't remember the exact code, but when I see my buddy with the scanner again, I'll get it. I should have the problem fixed before I see him though
Old Nov 29, 2007 | 10:38 PM
BillyBob69's Avatar
BillyBob69
I tried cleaning mine...Didn't help. Good luck with it...let us know how it turns out in case it is something different
Old Dec 19, 2007 | 07:50 PM
juli_emt's Avatar
juli_emt
I have a 99sd V10 experiencing same issues but I have a manual 5speed tranny does it also have speed sensor on it
Old Dec 19, 2007 | 09:10 PM
Jack_99V10's Avatar
Jack_99V10
K, well since we've had some snow up here in Buffalo I've had a chance to try out the ABS. What I've noticed is that because the light is on, when the ABS tries to kick in, the light goes off. I feel in the pedal that the ABS is working, but once I start rolling again the light comes back on immediately.
Haven't pulled it yet. Last time I worked on the truck was installing my DP Tuner... that was in a blizzard, and I haven't felt like crawling under there lately.
Old Dec 28, 2007 | 12:36 AM
victorygardenent's Avatar
victorygardenent
Great post - Can I trouble shoot a 94 aerostar the same way?
I am new too and glad I joined that was a heck of a post. I have been searching the internet for about a week and have found a lot of different hits for people with this similar problem. Of all the information I found the best was on this site so I decided to join and and within five minutes found barneys post and it really tied all the ideas I had swirling around together and shed some real positive light on an otherwise long and dark tunnel. Thanks a lot for making what was seeming impossible possible and giving me some confidence to move forward with the repair. I have a 94 aerostar van will i be able to follow these trouble shooting recommendations or does anyone know of any big differences I need to be aware of?
Old Dec 30, 2007 | 09:14 AM
Mercury45's Avatar
Mercury45
I know on 99-04 SD trucks the abs light will come on if there is a problem with the speed sensor in the rear diff, or either one of the front sensors goes bad - just from experiemntation - tried all this by unplugging them on my truck - i have a 2003 F250 5.4L gas
Anyway - With my rear diff unplugged I still get speed but also get an abs light.
I would check the three sensors - like the people above mentioned. When and if the wheel bearings start going bad (sealed assy they stink) the metal bits may get in there and cause the front sensors to mess up.
kenny
Old Dec 31, 2007 | 06:53 AM
victorygardenent
Brake light abs light and speedometer trilogy
I have had family visiting so have been unable to get under the van but I am going to get out there as soon as I am done writing this. I am a little concerned about being able to find the sensors. From diagrams I have seen the one in the back will not be a problem but I really have no idea where the two in the front are. Any info on that would be helpful. Also my horn and cruise control are not working and i read in a thread (that i can no longer find) that it could be some kind of a coil (i think) in the steering column. Any ideas? Thanks for the help.
Old Dec 31, 2007 | 08:19 AM
Mercury45's Avatar
Mercury45
im not sure how the 94 aerostar van works... I am not sure if it will have front abs or not.
kenny
Old Dec 31, 2007 | 08:36 AM
projectSHO89's Avatar
projectSHO89
Victorygarden:
You should start a thread of your own in the appropriate forum (Aerostar) as your system is substantially different than that used on the SD.
Old Dec 31, 2007 | 09:05 AM
Mercury45's Avatar
Mercury45
^^ good idea... but i cant say much, sometimes my posts go way off topic...
kenny
Old Jan 7, 2008 | 11:18 PM
victorygardenent
You are right about getting on the aerostar post. I am not really sure how I find that. Can one of you guys just let me know exactly how to do that and thanks for the help. I'm lucky i found the post at all let alone going off topic but thanks.
Old Mar 29, 2008 | 07:20 PM
  #28
pasaro's Avatar
pasaro
Question Abs light Stays on
My ABS light is staying on. I noticed that when I first start my truck with my foot on the brake the light stays off after the selt test until I relaease the pedal and apply the brakes again. After that it just stays on. The speedo is working normal and I cleaned both front wheel sensors. Also, I check for codes with my OB2 checker and there are no codes at all. Any suggestions?
Old Mar 29, 2008 | 08:06 PM
  #29
crw f250's Avatar
crw f250
Smile My fix is simple
My fix is simple
I put black electrical tape over the warning light,works just fine now.
Old Mar 29, 2008 | 08:31 PM
  #30
Mercury45's Avatar
Mercury45
check your brake fluid and brake pressure switch
kenny
