motor tapping
Old Jan 28, 2002 | 08:52 PM
1947HD's Avatar
1947HD
motor tapping
I have a 1978 F100 straight 6 that tapps loudly every time I give it gas. No tap at idle, and no tap while coasting...but touch the gas, and it hammers away. Is this an exaust manifold leak? Or maybe a bad valve tap? Thanks in advance for any ideas!
Old Jan 29, 2002 | 07:04 AM
rtbstrd's Avatar
rtbstrd
motor tapping
Assuming your timing is accurate, either diagnosis could be correct. You can use a stethescope to see if you can isolate the cylinder(s), better yet use a vacuum gauge.
Did this problem suddenly occur? Or if the truck has been sitting for a long time, sometimes a few lifters can stick. I had this problem, and an oil change with a qt. of Rislone solved it after 200 mi.
Something you can do quickly is pop the valve cover and check the valve adjustment, and anything obvious with your springs, guides, etc.
Old Jan 29, 2002 | 08:42 PM
1947HD's Avatar
1947HD
motor tapping
Thanks for the info....truck has been sitting for years, maybe it has a stuck lifter. Timing should be OK, but I'll check it tomorow.
Old Jan 30, 2002 | 10:26 AM
mantta's Avatar
mantta
motor tapping
