rinse inside man trans?
Old Nov 24, 2007 | 07:02 PM
mousetrap65's Avatar
mousetrap65
I am just wondering if is ok to rinse or flushout a np435 am thinking karosine
then flush with gearlube turning by hand to get karo out. its out of truck.
then i will fill with new lube reinstall top with new gasket and paint new cast
Old Nov 24, 2007 | 09:57 PM
75F350's Avatar
75F350
I am never a fan of chemical flushes. Never seem to be able to get all of it out, even after some clean oil has been run through it. Even dirty oil that comes out of a transmission, only means that suspended solids have accumulated in the oil, and is not indicitave of conytamination inside of the case. Instead, I would fill with fesh fluid, and re-check in a few hundred miles. If the oil is dark once again, i would flush it again. You will flush a few times regardless if you used a chemical, so you are simply eliminating the possibility of leaving any trace of chemical in the box, and ruining a bearing.
Doubt you will find that the fluid is real dirty after the first flush.
Old Nov 25, 2007 | 10:30 AM
mousetrap65
ok guess i use the karosine in heater for shop instaid
