Dirty Motor
Old Nov 24, 2007 | 01:43 PM
Turner-2000TJ's Avatar
Turner-2000TJ
Dirty Motor
I just picked up my first diesel and the motor/wiring is VARY dirty. Whats the best way to clean it? Can I use electrical contact cleaner to clean up the wiring or is brake clean a better option?
Thanks
Old Nov 24, 2007 | 02:30 PM
IceboxFX's Avatar
IceboxFX
I always use super clean to clean my engine. Its a degreaser you can get at auto parts store or walmart, I usually scrub a little too when using it. I wouldn't recomend using break clean cause it eats paint/plastic/rubber and it may eat away at an electrical connection or wire. You can also use gunk engine brite, that usually works pretty well too, it comes in a can and you can get it at an autoparts store or walmart aswell.
IceboxFX's Avatar
IceboxFX
also make sure to cover your air intake when your rinsing off
Old Nov 24, 2007 | 03:05 PM
kawa's Avatar
kawa
COOL --COLD ENGINE
I always use "Simple Green" full strengh, let it set for awhile then hose off with non-pressurized water. Make sure your engine is cold and do not concintrate on the electrical connections.
Happy washing
Rog
