Autospring
Old Nov 24, 2007 | 01:09 PM
kaerch's Avatar
kaerch
Autospring
finally got around to ordering my 1.5" kit, just got here and am lookin at it. i am gonna have to spin the strut 180 degrees when i reinstall it the way they have this set-up. is this how the 2 and 2 1/2s ar as well, or is it due to clearance issues on the studs with the smaller kit?? im not sure bout spinnin it when i go back together i would have to sy it will change the load on the spring... im not sure i like it...
Old Nov 24, 2007 | 01:26 PM
MBBFord's Avatar
MBBFord
Question
I didn't do that for my 2" kit....
Never heard of haveing to spin the strut 180*
Old Nov 24, 2007 | 07:32 PM
mattd17's Avatar
mattd17
it should only go on one way, due to the bolt pattern.... the bolts arent 120 degrees apart, so it only lines up in one position. when the kit is bolted on, the kits new studs will be in the same position as the factory studs.
ok, i was just re-thinking this, and i would bet that you are correct as for the bolt clearances with the smaller kits.... as for the 2.5" kit, the total thinkness is 1.75", so im not sure what the 1.5" kit measures, but im sure its a bit smaller.
Old Nov 24, 2007 | 07:36 PM
wreedZ71's Avatar
wreedZ71
Which autospring kits levels the truck?
Old Nov 25, 2007 | 08:48 AM
MBBFord's Avatar
MBBFord
The 2.5" kit levels the truck perfectaly, but some people have had trouble with it makeing the front slightly higher than the rear, and when it's level and you put anything in the bed or tow, then it looks like the truck is squating.
I used the 2" AS, and it looks pretty good:
https://www.ford-trucks.com/user_gal...&albumid=26793
